Antenna Gasket Replacement
Old Jan 21, 2017 | 09:42 AM
Rpaczan's Avatar
Default Antenna Gasket Replacement
I found a $13 gasket that was made for a VW but fits well on our Crossfires and is easy to install without having to remove the tailight and antenna base. First, use painters tape to mask area around base. Then use an exacto knife to cut away old gasket. Some of the gasket will be under base so that will need to be removed too. Once you have it removed use some adhesive cleaner to clean. Apply some silicone between fender and antenna and a bead on bottom of gasket. Fix gasket to narrower side and stretch to front making sure the edge goes between fender and base. Press down on gasket. Clean any silicone that squeezes out. Tape front of gasket to allow sealant to harden with front of gasket tight against fender. Allow to dry for 24 hours. Clean any excess silicone. (Step not done, use black trim conditioner on the base plastic).
http://www.ebay.com/itm/151888584933...%3AMEBIDX%3AIT
Old Jan 21, 2017 | 10:08 AM
Kingdav1954's Avatar
Default Re: Antenna Gasket Replacement
Great job and it looks pretty darn good and I think the administrators should consider this for a sticky.
Old Jan 21, 2017 | 10:24 AM
Yep, but I found an easier way.
I ordered 4 antennas from China and although the wiring wasn't correct, the masts and the rubber gasket were. For $7.75 each and free shipping, not a bad deal.
Car Radio FM Amplified Booster Antenna for BMW Z3 Z4 M3 Toyota VW Passat B5 | eBay
Old Jan 21, 2017 | 10:40 AM
Rpaczan's Avatar
That looks like a good option. Did you splice the connector from the old antenna on to the new lead?
Old Jan 21, 2017 | 10:58 AM
NO, I re-used the OEM body with the OEM wiring.
I just replaced the mast and the gasket with the parts from the Chinese one.
( I gave one to Max, I still have 2 of 'em left )
Old Jan 21, 2017 | 11:03 AM
You have an eye for a bargoon.
Better buy whatever you need now, I hear there will be a big levy on imported goods soon.
Make that antenna in Dertroit and it will be $75 each.
We can all get stuff like this from China cheaper than the stamps to send it back to China.
Old Jan 21, 2017 | 04:35 PM
Car Radio FM Amplified Booster Antenna for BMW Z3 Z4 M3 Toyota VW Passat B5 eBay
thanks ala I need those gaskets so I'm going to order some of the ones you did and the extra mast's won't hurt either.
Old Feb 10, 2017 | 12:21 PM
eruby's Avatar
Thank you. My gasket was rotting away and I didn't know how to fix it. I ordered the antenna from the post above, waited, waited, waited then received the antenna. The OEM antenna was pretty easy to access. I have a roadster so I opened the back lid and accessed the underside from there. 22mm socket to remove the nut. The wiring has a connector about 8" in from the base. Disconnected the wires, pulled the base out, cleaned up the hole area, put the new gasket on, reassembled and done. Probably 15 minutes total. The gasket is almost an exact fit. Thank you again for this tip.
Old Feb 10, 2017 | 01:07 PM
You are most welcome !
Old May 31, 2017 | 07:57 AM
Crystal's Avatar
Thanks George, I am going to give this one a try. I do not need a new antenna, only the gasket, but Kristi's Roadster does need a new antenna, so I'll use the antenna on her Roadster.
Old May 31, 2017 | 11:59 AM
RED DOG's Avatar
Dr. George, THANKS for all your research and links. I ordered two new antenna gaskets for my roadsters!
Best personal regards,
Old Sep 4, 2021 | 09:01 AM
Daveace's Avatar
Remove trunk lining, remove rear light 3 x 8mm nuts disconnect harness to light, 22mm socket to remove base nut, disconnect antena wire fit new gasket replace in reverse order the original gasket part no is A193 820 05 89 IN CASE YOU WANT THE REAL THING Hardest part is disconnecting the back light harness and putting lining back on.
Old Jun 17, 2023 | 03:10 PM
drluccia's Avatar
Thank you for the description and photos. I did this this morning and it went really smoothly. I was very pleasantly surprised.
