SRS light on after Takata airbag recall
So here is a quick summary of my story and now problem
- Bought the car last May w/ 62K miles. 2007 Coupe w/ 6 speed. Have not had any issues
- Takata airbag recalled shortly after buying it, no airbags available.
- Chrysler sent notice in mail in Feb so I setup appointment to have it swapped
- Swapped in 1 day and I picked it up and everything seemed fine
- Approximately 2 weeks go by (car driven maybe 40-50 miles) and SRS light comes on
- Kind of forgot about it and didn't call dealership back for a month, they said to bring it back in
- At dropoff they informed me if not related to recall or workmanship, they would charge $99 diag fee. I thought ok, but you guys were just working in the system.
- At dropoff also asked them to do my state inspection but he wasn't sure they could w/ SRS light on
- Later that day they informed me they didn't have the right SRS scan tool and would have to get one from another source
- 2 days go by, no contact
- 3rd day, dealership calls and says they couldn't pinpoint the issue and that scanner was not getting "good voltage in the SRS wiring" Stated they needed $688 to diag wiring further
- Told them no I would figure it out on my own and asked about the state inspection. The service writer said he forgot about it but asked someone while I was on the phone and said due to SRS light on, they couldn't do the inspection.
- Picked up the car the next day... Service department couldn't find keys or car for 30 minutes. Finally found it
- When I got in, realized 58 miles had been put on my car and the Mileage out was 27 miles less than it had.
- Asked the service writer why it was driven 58 miles, he did not know but initialed and wrote the correct mileage on my ticket
- Called the service manager and asked why they drove my car, she checked with the shop foreman and then said they had to for the state inspection to clear the "monitors"
- I advised them that the state inspection wasn't even done and that no check engine light was on, so there would not be any "monitors" or sensors to clear
- They did not have an answer and are still researching.
So in summary, I now have non functional airbags, I cannot confirm they even did a check on SRS system (I'm starting to believe they didn't). And it is looking more and more likely that they went joy riding in my car over 3 days while they were NOT looking into it!
Any recommendations? I'm worried that A)They damaged the clock spring or wiring if they didn't install new bag correctly or B) There is an issue with the new airbag communicating with control module and Chrysler nor Takata will want to investigate or admit responsibility
Any help would be appreciated
Call FCA customer hotline and start a file. Have your VIN handy.
(800-247-9753) 800-Chrysler
Good luck. I get my recall done Thurs.
thanks harbor, I will see what they say. Good tip Graphiteghost, I should have done that to cover myself. I went in far too trusting and now face an uphill battle :-)
It is fairly common for most of these CDJR service centers to NOT have the proper scan tool to reset the SRS. Nearly all of them have to borrow a unit from another dealer or purchase a scanner to perform the SRS test / reset, if they need to after replacing the airbag module.
I would encourage those that haven't had the airbag recall performed to checkout the other threads on this issue. Many of the experiences some are having have already been encountered by those of us that went before you. Quite a few tips have been given to help avoid issues with planned recall repairs. Here's a thread that has quite a bit of information within it: Air Bag Recall
I'd almost rather take my chances with these airbags than deal with Chrysler dealerships.
I've already taken a hit to the face from one of them. Can confirm, didn't die
What year XF was it?
Harbor, did you get your car back today? Update on me, I called FCA customer hotline, in a nice way they stated could not refund $99 diagnostic fee, and stated that they sided with the dealership that there is an external issue going on not related to the recall. I stated that I disagreed and he said he would "document" my concern. ha! so basically I'm out of luck. The dealership has not followed up with me either on the airbag or joyriding issue.
https://www.crossfireforum.org/forum...tml#post885701
Try calling the hotline again and have them refer you to another metro Houston dealership, preferably with a XF tech.
So I spoke with a higher up service manager from the dealership yesterday and he was helpful. He seemed very concerned why they drove the car and did not actually test the srs system. He admitted that they did NOT hook it up to the Star scanner and that their dealership had to borrow/rent one from another dealership anytime they needed one. He stated he would refund me and look into getting the scanner. He mentioned they had another crossfire there also that had the recalled airbag swapped and that the SRS light also came on soon after. Uh oh, looks like we may have some bigger problems with this recall.
A major supplier for lane-departure warning systems for Nissan struggles with this issue a LOT. I'm one of the guys that approves the Parts Submission Warrants for these SW changes, and ten times out of nine there are issues detected downstream when the factories overseas have to do PPOF replacements.
TL,DR version -- he needs to borrow Star-DAS to fix it. But it's fixable.
I'm going to go out on a limb here and say that the replacement unit built for market claims has a line (or five) of code that doesn't jive with the OEM airbag control unit, and it's popping the code. With the ever-increasing complexity of systems in cars these days, it's a very common problem if the past-point-of-fit (PPOF) component is going into a 10+ year-old car.
