Alternator
Old Jun 15, 2017 | 01:42 PM
deltacrossfirebob's Avatar
Default Alternator
Need new alternator
Looking for input on the best, primo unit to purchased
Also plan on replacing belt.
Anything else???
Thanks guys and dolls
Old Jun 15, 2017 | 01:51 PM
Default Re: Alternator
get the complete belt kit :
https://www.fcpeuro.com/products/mer...it-e320beltkit
As to the alternator, if yu have a Valeo, get a Valeo.
If you have a Bosch, get a Bosch.
Old Jun 15, 2017 | 01:58 PM
Ala_xfire
Thanks for the speedy reply
I was planning on the belt but did not know about a "kit"
Value your input so will go with the full kit
Thanks
Noticed that there are two different units
Oreily's here has either one at $190.00
Thanks again
Old Jun 15, 2017 | 09:00 PM
I think I paid $120 for the belt tensioner alone, back when my Graphite started making funny noises.
Old Jul 1, 2017 | 02:24 AM
Ala_xfire
Ordered the kit .
Now have to figure which alternator I have.
Have to pull it for that???
Did not see any tags/labels on it.
Thanks for all the help
Old Jul 1, 2017 | 09:42 AM
Originally Posted by deltacrossfirebob
Ala_xfire
Ordered the kit .
Guess so with no visible labels, not that hard to do if you remove the fan shroud first.
Don't forget to disconnect the negative battery cable before you start, wouldn't want that big positive alternator cable end coming in contact with the frame anywhere - can you say Crossfire flambeau ?
Old Jul 1, 2017 | 10:55 AM
Bosch and Valeo make replacement alternators for each others alternator, so the correct Valeo will replace a Bosch alternator and vice versa. There is a list somewhere here with the part numbers. The cable attachment pattern will indicate the OEM maker. Generally Bosch supplied the NA alternators and Valeo the SRT alternators but that is not always the case. Confusion reigns.
Old Jul 27, 2017 | 06:43 PM
Thanks for all the much needed input.
Fan shroud out.
Two bolts out.
How does the unit now come out??
Battery is also disconnected.
Old Jul 27, 2017 | 06:47 PM
You may have to pry on the bolt sleeves a bit to get the unit to drop from the mounts.
Next step is to kinda rotate it around so you can remove the bolt-on wire and the plug-in harness.
Then you just fiddle with it until it comes out.
Old Jul 27, 2017 | 07:52 PM
To loosen the sleeves which are pushed against the alternator you use a soft mallet or lever and move the alternator back and forth loosening the clamping sleeves. The sleeves which are around each of the bolts are pulled by the bolts forward pushing the alternator into position against the fixed forward stop.
That's how I remember it is done.
Naturally I may be a little wrong but that is the basis of the clamping arrangement.
Old Jul 28, 2017 | 01:32 PM
Finally out.
Sure not like the good old 60's when everything was upfront and easy to get at.
Still love the car.
Ordered a direct replacement from DB Electric.
Take a day longer to get here than AutoZone or Oreily but $100.00 cheaper
Same warranty and all.
So now wait
Thanks again to you all for the great advice.
Much appreciated
Old Jul 28, 2017 | 08:16 PM
A man being a "little' wrong?
That's the basis of a good marriage.
Old Jul 28, 2017 | 08:17 PM
I got mine from NAPA in five hours. But that's cause I live near Atlanta, these NAPA stores get daily deliveries around 11-2pm, if you order by 8am, it's here same day.
ALmost makes up for the TRAFFIC here......
Old Aug 15, 2017 | 07:28 PM
Thanks to all for their input
Went from water pump to altnerator and a new battery
Also added the belt/ pulley and tensioner
Thanks again
