oil
Old Mar 13, 2018 | 08:57 PM
wgc's Avatar
wgc
Exclamation oil
Hi is Mobil I 15w50 synthetic to much for Louisiana very hot here ? Gary
Old Mar 13, 2018 | 10:20 PM
Default Re: oil
I would not put any weight in there not on this list:
https://bevo.mercedes-benz.com/bevolisten/229.3_en.html
Personally, I run 5W40 here in North Georgia as 0W40 is just too damn thin.
I was running 5W50 in the summer, but it's just too thick for a cold start below about 45F. Try Mobile 1 5W50 if you are concerned about the heat of summer, but again, if you start the engine at 45F or below, you WILL hear the lifters banging for up to 60 seconds, it's just too thick. Other than that, find a 5W40 on the above list and go with that.
Old Mar 13, 2018 | 10:55 PM
wgc's Avatar
wgc
Red face Re: oil
Thanks Pizza Guy. Gary
Old Mar 14, 2018 | 12:36 AM
Default Re: oil
I think you are mixed up a bit, the lower number is for the colder temperatures.
That is what I understand anyway.
Old Mar 14, 2018 | 08:39 AM
Default Re: oil
I can only report what I've observed, Dave. Try it and see. I was a BIG believer in 5W50 for a while, you saw how I preached about it - but when I stopped putting enough miles on for two oil changes a year, I quickly realized that 5W50 below about 45F was just to thick upon startup. 5W40 (and 0W40 for that matter) do not yield a "tapping engine" at even 30F.
And yes, I know about the "it performs like the first number at cold temps and the second number at high temps" claim - but again, I can only report what I have directly observed.
Old Mar 14, 2018 | 09:57 AM
wgc's Avatar
wgc
Exclamation Re: oil
if I put 5 qts of 5w40 and 3 qts of 5w50 for summer . I live in Louisiana
Old Mar 14, 2018 | 10:02 AM
Default Re: oil
Then you'd have 8 quarts of 5w/43.75
Old Mar 14, 2018 | 10:05 AM
Default Re: oil
Go with the 5W40, the engine stays about the same temperature when hot.
The cocktail you propose would look good with a little umbrella on the top of the dipstick.
Old Mar 14, 2018 | 10:09 AM
wgc's Avatar
wgc
Exclamation Re: oil
Do you think that is a good mix 5- 5w40 and 3-5w50
Old Mar 14, 2018 | 10:17 AM
Default Re: oil
Do what you want, it’s your car.
Old Mar 14, 2018 | 10:21 AM
wgc's Avatar
wgc
Red face Re: oil
Thanks will put 8- 5w40 With no umbrella
BlazingSaddle
Sep 29, 2021 11:19 AM
ws6vert
Jun 13, 2021 10:04 AM
rodimus
Jan 19, 2009 04:15 PM
ingsoc39
Aug 20, 2008 12:49 PM
blacklimitedcoupe
Oct 14, 2007 01:15 AM
