Remote would not open door car would not start
Old Apr 4, 2018 | 10:17 PM
maggy55's Avatar
Default Remote would not open door car would not start
Okay I've read through several threads on this , but doesn't seem to be a definitive answer. I drove my car , everything was normal. Came back a couple hours later, pushed the remote nothing. Unlocked driver door with key, alarm went off. Got in the car , attempted to start it, nothing. Engine did not turn over , dash lights up. Removed fuse 9 alarm goes off. Disconnect battery for several minutes, reconnect. Remote still doesn't work . Open door with key, no alarm. Put key in ignition, car starts. Drive home. Light on tow switch blinking red the whole time. Get home, turn off car. Put fuse 9 back in. Remote works as normal. Can lock and unlock car and start car. Obviously the alarm and anti theft system was activated and I couldn't shut it off, so the car wouldn't start. I thought when you open the car door with the key that it turns off the alarm system ? I checked the remote batteries and they're good. Car battery seems good ,12.6v ,as well as ground. Alternator putting out 14.2 v .I'm a little confused where to start trouble shooting. Is this the Skreem, the remote receiver in dome light assembly, or just a fluke?
Old Apr 5, 2018 | 12:19 AM
maggy55's Avatar
Default Re: Remote would not open door car would not start
Also, I thought unlocking the door with key would unlock the trunk as well?
Old Apr 5, 2018 | 11:24 AM
Steve Jr's Avatar
It should unlock everything at once. You can program it to unlock one or both doors , on the FOB. I don't know if that transfers to the key.
Old Apr 5, 2018 | 02:26 PM
The key overrides the fob settings, I am guessing an alarm issue. Maybe it ha shorted out inside. Disconnect alarm and see what happens. Not just removing the alarm fuse.
Old Apr 5, 2018 | 03:10 PM
Mrmiata's Avatar
Kinda my thoughts when I saw this too... hit the panic button and see if it sounds like it's on crack... won't "rule it out" if it sounds normal.. but will confirm an issue if it does..
Old Apr 5, 2018 | 06:23 PM
This might not apply here, but look for water in the right rear trunk cavity. Good luck!
Old Apr 5, 2018 | 08:46 PM
maggy55's Avatar
Put a new alarm siren in last year. Chirps when locking and unlocking. Just tested panic button, works as expected,
maggy55
Jul 26, 2018 09:50 AM
texas t
Mar 12, 2012 08:15 AM
popeye
Apr 10, 2010 03:20 PM
rcompart
Jul 5, 2009 08:31 PM
Tonyitalian2
Dec 18, 2007 01:03 PM
