Oil pressure gauge
Old Apr 22, 2018 | 05:48 PM
DHS's Avatar
DHS
Default Oil pressure gauge
As i mentioned in my other post I want to put in some VDO gauges, oil temp and pressure. I have a chose of a few scales, I would like to see minor changes so that means going with lower limits. If I get one too low the gauge will just stay pegged all the time, does anybody have those numbers where these two numbers run?
This is the part I had done for the gages.
Old Apr 22, 2018 | 07:06 PM
Default Re: Oil pressure gauge
With 0W40, oil pressure will run as low as 3psi at idle. 5W50 will yield idle psi of 8-9psi.
With a cold engine, you will see as much as 80-90 psi even at idle, even with 0W40.
At operating temperatures, the 2000-3000 rpm range will yield 35 to 55 psi depending on what weight oil you run.
*The above numbers come from what I saw with a ProSport Electric Oil Pressure Gauge.
I replaced the sending unit at one point (mounting it directly to the port on the engine caused it to fail, I suspect due to heat) - and saw the same readings with the replacement sending unit.
Old Apr 22, 2018 | 09:04 PM
DHS's Avatar
DHS
Thanks, so the 0-80 psi would be the one for driving, and let me see small changes. Where on the engine did you place the sending unit? This for my NA.
Dan
Old Apr 22, 2018 | 09:13 PM
Dan
The oil pressure port is in the WHITE circle.
Old Apr 22, 2018 | 09:21 PM
DHS's Avatar
DHS
Thanks, not hard to find!
Old Apr 23, 2018 | 07:27 AM
See this thread :
https://www.crossfireforum.org/forum...e-project.html
Old Apr 23, 2018 | 11:51 AM
Remote mounting it is VERY important, the aftermarket senders do not appear to tolerate heat like the factory sending units of years past.
Old Apr 23, 2018 | 01:39 PM
DHS's Avatar
DHS
yes i like the remote that Howard did have printed the parts list. also the VDO 80psi gauge should work fine.
Dan
MikeR
Oct 9, 2008 03:59 PM
wdt1971
Aug 29, 2008 08:50 AM
wdt1971
Aug 20, 2008 09:31 PM
dynamicS
Jun 27, 2006 04:03 PM
Wayne1992
Mar 24, 2005 07:00 PM
