Engine stops randomly
Old Apr 29, 2018 | 07:02 AM
mozzer's Avatar
Default Engine stops randomly
Hello,
Since a few months, the engine of my Crossfire (2004 - manual) stops randomly when I drive (with all the lights on). I performed this operation several times :
.If I do nothing, the engine restarts after approximately one minute.
.If I unlock and lock with the remote, the engine restarts immediately.
I'd say that this is a pattern but, last time the engine stopped, something else happened : the cooling fan ran fast and I didn't manage to restart (I tried during 10 minutes) even with the unlock/lock operation. Then a tow truck brought the car to the garage and she started immediately... I read a lot of threads about this issue and it seems that it could be related to the RCM and especially the relays/solders.
What I'd like to know is if a RCM failure would have something to do with the unlock/lock remote operation. If not, what do you think the issue could be (ECU, skreem...) ?
Thanks,
Fabien
Old Apr 29, 2018 | 08:21 AM
Default Re: Engine stops randomly
Yes, most likely the RCM is the root of all your evils.
Old Apr 29, 2018 | 09:00 AM
Originally Posted by mozzer
Hello,
Thanks,
Fabien
Having read of this problem for over twelve years now and to minimize it happening again while out on the road I think I would buy and fit a new RCM and a CPS. The resoldered units may be fine but early in the morning waiting by the side of the road for a tow that is likely to cost more than a new RCM and new CPS you may regret your earlier solution. A new RCM and sensor can be had for less than $200.
Fix two possible problems at once rather than wait to find you have put in or fixed the wrong part.
I carry a spare of each part in my trunk but if I had your problem I know what I would do.
Old Apr 29, 2018 | 02:11 PM
mozzer's Avatar
Thanks ala_xfire and onehundred80.
Do you advise this RCM model ?
https://www.rockauto.com/en/catalog/...rol+relay,3188
Also, do you have a link for the CPS ?
Old Apr 29, 2018 | 03:26 PM
Yes, that's a good RCM.
CPS : https://www.fcpeuro.com/products/mer...sor-0031532828
franklindm
Mar 14, 2020 12:23 PM
Tar Heel David
Apr 16, 2018 10:45 PM
Grant JC
Nov 12, 2011 10:40 AM
all_Bran
Jan 6, 2010 06:52 PM
Zad
Dec 28, 2009 10:20 AM
