Driveshaft length
Old Sep 15, 2018 | 10:02 AM
loggato's Avatar
Default Driveshaft length
Does someone have a driveshaft they can measure from flange to flange?
I would like to compare it to a couple of Mercedes SLK driveshafts that I have laying around.
thank you
Old Sep 15, 2018 | 10:15 AM
Default Re: Driveshaft length
thank you
been there done that, none fit. the short section on some are the same but out of balance.
if you look where two halfs join (slip) you will see two notches on one half ,,, and one notch on the other ,,they need to line up when the driveshaft goes together for balance. do a search on driveshaft
Old Sep 15, 2018 | 10:29 AM
loggato's Avatar
Ok let me be more specific. I've swapped a 4.3L M113 V8 into my SLK230. the stock 230 driveshaft puts the engine too far back in the engine bay and there is no room for the throttle body tube or exhaust. now when I put the 6 speed manual from a crossfire in it (with accompanying driveshaft), it puts the engine where it should be. (basing this on comparing to pictures)
But now I am putting an AMG 5.5L in it, and going back to Auto, but I need to know if the Crossfire has a longer (automatic) driveshaft than the SLK230. my guess is it's about 2" longer but need to be sure before buying one.
Old Sep 15, 2018 | 01:51 PM
with my 5.4 using the V 8 , the transmission mount fit in stock location ,so did the drive shaft ,, i would say if your slk230 was auto and now u are using a 5.4 with its tranny bolted to it the stock drive shaft should fit my stock drive shaft lasted 4 years with 300 runs down the 1/4 mile running in the 10's ,with over 600 hp so yea use it.
Old Sep 15, 2018 | 04:08 PM
loggato's Avatar
That's just it, the Crossfire driveshaft would put the V8 in the correct location because Mercedes redid a couple of things after 2001 to accommodate the V6. my SLK is a pre-2001 and the V8 was a couple of inches farther back because of how the 4 cylinder was positioned.
I just need to make sure that the Crossfire driveshaft is indeed 2" longer than my SLK230 shaft.
Old Sep 15, 2018 | 08:16 PM
I am in the mountains of Ga,,, for the tail of the dragon, so i can't measure it for you. make sure your center bearing hanger fits or u can move it to fit.
LugNut
24
Dec 19, 2013 09:21 PM
Infinite
Jul 16, 2010 05:54 PM
ViffeR
May 12, 2009 05:17 PM
v8valiant
Sep 21, 2008 09:25 AM
silver98m3
Sep 2, 2005 02:03 AM
