Starts but does immediately
Old Sep 28, 2018 | 08:32 PM
Imbubba's Avatar
Default Starts but does immediately
I recently purchased a 05 Crossfire,the guy I bought it from drove thru a big puddle of water and it sucked water into the intake,needless to say the motor was trashed,but it still ran. I bought an engine and installed it,now I can't get it to start,I'm having alot of them same symptoms as everyone else,keyfob doesn't work,no alarm sounding off though,trunk locked,anyways,all I did was swap an engine from a running car,and now it wont start,have to keep resetting the computer to get to crank just to get it to start for about one or two seconds. Any help would be greatly appreciated.
Old Sep 29, 2018 | 07:46 AM
Default Re: Starts but does immediately
You didn't happen to swap any of the modules in the black box by the battery, did you ?
Old Sep 29, 2018 | 10:11 AM
Imbubba's Avatar
No I did not. The only thing I did in the black box was disconnect the wire harnesses for the engine.
Old Sep 29, 2018 | 11:27 AM
OK, was asking cause the SKREEM and PCM have to know each other.
The symptoms you described are SKREEM synptoms.
Old Sep 29, 2018 | 11:54 AM
Imbubba's Avatar
Does that mean I need to replace the SKREEM module,and if so,where can I find an affordable one?
Old Sep 29, 2018 | 04:38 PM
You can source the SKREEM from Rob at Needswings, but in your case I would advise trying to contact him first and get his opinion on your situation.
  • 1-586-531-1413 10am-5pm EST
Old Sep 29, 2018 | 06:40 PM
Imbubba's Avatar
I will certainly give him a call,I truly do appreciate your assistance with my problem. I will report back to let you know what I find out,thanks again.
BlazingSaddle
Jun 6, 2019 09:18 PM
DarksideXF
May 30, 2019 11:02 AM
Truesy
Oct 4, 2018 10:50 PM
PNA
Mar 11, 2018 05:43 PM
mikerose
Aug 23, 2011 08:23 PM
