Interior (Map & Trunk) Lights
Old Jul 16, 2019 | 10:05 AM
Gianolio's Avatar
Default Interior (Map & Trunk) Lights
Hi everyone - having problems with my interior lights and couldnt locate a similar thread. Map and trunk lights work but there's no on/off when opening the door. I can turn the lights on and off from the console above the windscreen. The door 'pins' seems to push in and out OK but lights wont come on when any doors are opened. Does any one have a fix?
Cheers
Old Jul 16, 2019 | 12:38 PM
Default Re: Interior (Map & Trunk) Lights
Cheers
There is a slider switch as well as the ON/OFF push button switch, it determines if the door switches work or not work. It is beside the push button switch.
Old Jul 16, 2019 | 12:56 PM
Gianolio's Avatar
Yes, thanks. That works fine but still has no effect on the lights coming on when the door is open
Old Jul 17, 2019 | 09:39 AM
There is a trim piece on the doors that contacts the switch, some people had cars where this had been removed for some reason and the light stayed on all the time, l have not heard of the opposite.
Check out the slider switch.
Old Jul 17, 2019 | 09:49 AM
Gianolio's Avatar
OK, thanks - I will investigate the slider switch more and report back
BobG
Jul 18, 2020 01:45 PM
BibaResto
Oct 28, 2017 02:28 PM
BobG
Nov 30, 2016 01:11 PM
BibaResto
22
May 19, 2016 09:55 AM
itsky
Apr 6, 2015 04:57 AM
