very little heat???
Old Oct 23, 2019 | 04:35 PM
leroyvette's Avatar
Default very little heat???
Recent purchase of 2005 roadster----just now cool enough for heater---only slightly warm air from floor/dash vents---blower speed seems slower than my coupe, but does blow---engine also seems slow to come up to normal temp---??? any ideas?? Thanks, Leroy
Old Oct 23, 2019 | 05:29 PM
Default Re: very little heat???
What does the engine temp gauge read once warmed up?
Old Oct 23, 2019 | 05:56 PM
There are two valves going to the heater, one for the left and one for the right. These are under the hood on the passenger side and close to the black box with the RCM inside. These get jammed or fail, the rotary dials on the left and right of the AC panel operate these by varying the flow through the valves.
If the air conditioner works it will be these valves.
Old Oct 23, 2019 | 09:48 PM
leroyvette's Avatar
temp guage comes up to normal operating temp, but does seem to take much longer than my coupe---I was aware of the water valves on pass side, but after engine comes up to normal temp, valves are still cool to the touch---guess this could be the problem---thanks for the response. I have a running parts car--might take the valve from it---are the valves repairable??
Old Oct 23, 2019 | 11:31 PM
They are repairable, there is a DIY article in the howtos.
Old Oct 24, 2019 | 11:53 PM
Did you check and see if the coolant heater pump is working? Doesn't it run when you call for heat? Or, does it only run when you select 'rest' mode.
Old Oct 25, 2019 | 12:44 AM
REST mode only.
Old Oct 25, 2019 | 11:56 PM
REST mode only.
Thanks George... Its been a while since I delved into the HVAC system. Still trying to find a A/C head to troubleshoot but seems it isn't going to happen.
IF the pipes going to (and through) the valves do not get hot in 'rest' mode then your valves are either clogged, pipe or pipes are clogged, or the pump isn't running.
Old Oct 28, 2019 | 06:05 AM
Speedy4x4's Avatar
In several vehicles, I get some barb fittings, water hose quick disconnects and a ball valve and back flushed the heater core, with a water hose, to clean it out,
dskul1
Apr 19, 2014 03:37 PM
cross><hair
Sep 2, 2009 03:52 AM
ZERACER
Mar 11, 2007 06:31 PM
andrew
Nov 28, 2005 05:59 AM
ejc45carter
Apr 1, 2005 10:11 PM
