No high beams
Old Mar 18, 2020 | 12:56 PM
rednrollin's Avatar
Default No high beams
Anybody have this issue where suddenly I have no high beams however no fuses are blown Any direction would be greatly appreciated. I learned this last night while driving on a mountainous road in rainy conditions.
Mike
Old Mar 18, 2020 | 01:19 PM
Oldschool's Avatar
Default Re: No high beams
Sounds like another "multi-function" switch failure. I replaced mine last week ....... was at first overwhelmed but this forum is awesome with info and links. There is even a how to repair the faulty switch!!!
I chose to buy a new switch and install it (found it on a sale for like $200.00 Ebay has them for under $100). I took my old switch apart and fixed it (now on shelf for who knows what)........... I would send it to you should you desire.
Old Mar 18, 2020 | 01:48 PM
Oldschool's Avatar
This is the link for the switch I bought https://www.mbpartspros.com/oem-part...SABEgIQK_D_BwE
Old Mar 18, 2020 | 04:45 PM
rednrollin's Avatar
That would be great! If you don't mind please call or text my cell and u can educated me a lil more!
Mike 530 788-6089
Old Mar 19, 2020 | 10:26 AM
Oldschool's Avatar
Check out this link https://www.pelicanparts.com/techart...el_Removal.htm
and this one https://www.pelicanparts.com/techart...eplacement.htm
You need not remove the hood release or the plug-in from the trim panel; just let it hang (picture #10 and #11)
There are other links on this site to R and R this switch ... I felt warm and fuzzy using these two links and printing out the pictures for reference as I progressed.
One further note: The yellow air bag plug just pries out from the silver mount (picture #3).
I had to use an air impact to remove the 10mm allen bolt at the steering wheel (rent an electric one if you have no access).
This was a bit out of my wheel house. I wanted to use a NEW switch so I would not have any issue with a possible used bad switch.
rmcdaniel12
Nov 1, 2014 03:38 PM
brewski
Jan 16, 2010 03:59 AM
TX_xfire
Aug 21, 2009 03:15 PM
dkriegh
Jun 11, 2008 11:56 AM
dkriegh
May 19, 2008 04:45 AM
