Convertible Top
Old Jul 17, 2020 | 05:02 PM
Pudgie's Avatar
Default Convertible Top
I have a 2007 Crossfire Roadster. I had the top replaced and now it won't go up or down (I guess it can be done manually). I have taken it to shops in Florida and now CT. Nobody has been able to fix it. Seems the problem is when the top was put back on the computer software was erased. This is what the last mechanic said. The BAS/ESP light on the dashboard is also on. The mechanic called Chrysler and Mercedes only to be told that this software is not available any longer. Is this legal and how do you just stop making a part for a car? Any suggestions would be helpful as I'm at my wits end. The car, with the exception of the top) is all original and only has 16,000 miles on it. If anyone has answers please email me at Pudgie1230@aol.com
Old Jul 17, 2020 | 06:05 PM
Default Re: Convertible Top
Seems the problem is when the top was put back on the computer software was erased. This is what the last MORON said.
I fixed your typo.
This is not funny, but it almost is. I'll email you.
Old Jul 18, 2020 | 10:59 AM
Old Jul 18, 2020 | 12:23 PM
When you unhook it from the windshield do the windows go down? Does it make any sound when pushing the button? Does the light in the button flash? Need more info to evaluate.
Old Jul 18, 2020 | 12:44 PM
I've moved our discussion to the phone - we've talked and she is verifying things like that.
I posted my video for her after we talked about the problems.
Old Jul 18, 2020 | 03:06 PM
DualSportDad's Avatar
You have taken it to shops in Florida, do you come to Florida often? If you ever find yourself in SW Florida come by my place and I'll get it fixed up for you.
Old Jun 16, 2021 | 06:43 PM
Pudgie's Avatar
HI! I finally got my convertible top to go up and down. I now have a problem with the BAS/ESP light staying on. I was working with a guy name MARK CHRISTOPHER however I can't reach him and I cannot for the life of me figure out how to start a thread or a post. So frustrating. The car is a 2007 and it only has about 16,500 miles on it. As soon as I can figure out how to fix the car, I need to sell it. It's in CT and I'm in SC. HELP PLEASE!
Thanks
You can email me at Pudgie1230@aol.com
Old Jun 17, 2021 | 09:24 AM
Doc78's Avatar
Have you tried starting the car and turning the wheel all the way left then all the way right then bring it back to center?
If you have had the battery disconnected or replaced this is a common problem.
Hope this helped.
Old Jun 17, 2021 | 10:20 AM
Hope this helped.
I have had two Crossfire since 2005 and I have disconnected the battery many times since, only once did that light come and it went out as I backed the car from the garage. I did the lock to lock exercise just as a precaution just in case it did require some reset.
This reset is trotted out every time that light comes on and frankly I think it is just a habit that most of the time does not work.
Old Jun 17, 2021 | 10:49 AM
Doesn't cost anything to try and it worked for me two times. I would try that before I just start replacing parts, as many do.
Old Jun 17, 2021 | 12:49 PM
I said I did it that one time but most times it does not as there are other problems.
We had one member here who posted the possible solution to many problems was a throttle reset, naturally it is not.
Old Jun 17, 2021 | 06:07 PM
Doc78's Avatar
Throttle reset link:
https://www.crossfireforum.org/forum...ttle-reset.pdf
Old Jun 22, 2021 | 08:29 AM
Pudgie's Avatar
Hi, what is the lock to lock exercise? I sill have the light on problem after doing the turn to the left then turn to the right.
Old Jun 22, 2021 | 12:17 PM
Doc78's Avatar
The turn all the way left and right and back to center with car running is the lock to lock exercise.
Have you tried the throttle reset yet?
Old Jun 22, 2021 | 12:58 PM
Pudgie's Avatar
I'm not real good at all with cars so I have no clue what a throttle reset is. Thank you!
hemi135
Nov 12, 2021 03:48 PM
cappak
Aug 13, 2020 03:16 PM
Ironman32
Aug 3, 2017 11:24 AM
orbit398
Jan 17, 2014 09:04 AM
houstondan
Jun 18, 2004 08:45 PM
