Over center switch bypass
Old Aug 21, 2020 | 09:41 PM
Belkin7's Avatar
Default Over center switch bypass
I own a 2005 convertible and they finally figured that I need to replace the over center switch part # 05142205AA.
I've tried to locate the switch and I'm not having any luck. Is their a way to bypass this switch. If I latch the top closed, the top becomes unresponsive until
the top is manually retracted and this is not a fun way to get the top to work. Any suggestion would be helpful
Randy
Old Aug 21, 2020 | 10:58 PM
Default Re: Over center switch bypass
The "over center" switch? Where in the service manual did you (or 'they") find that term?
What switch are we talking about? IF you are saying the top goes UP but not DOWN,then it's either the TOP OPEN switch or the DIVIDER SWITCH.
Kind of sounds like you are talking about the TOP OPEN switch. Bypassing the top open switch is a BAD idea, you can bypass the divider switch, but the top open switch is not one I'd bypass.
Old Aug 21, 2020 | 10:59 PM
Here is a thread on the top sensors, what they are called, etc:
https://www.crossfireforum.org/forum...p-sensors.html
Old Aug 22, 2020 | 12:54 AM
Belkin7's Avatar
Sorry I forgot a few words when I typed
Power Top Over Center. Switch
Old Aug 22, 2020 | 08:29 AM
Shamrock's Avatar
Located on the power top rail approximately in the middle (above micro switch), No longer available. Search salvage yard or someone with a parts car willing to sell it.
Black03AR
Jun 18, 2010 04:47 AM
Rich W
Apr 13, 2010 07:36 PM
pt0001
Feb 5, 2008 11:04 PM
bobo54545
Jan 11, 2008 08:18 AM
white hot
Apr 17, 2007 08:34 AM
