Multiple Cylinder misfires - Check Engine
Old Mar 18, 2021 | 04:20 PM
jimcross's Avatar
Default Multiple Cylinder misfires - Check Engine
I got several codes indicating cylinder misfires. Engine running very rough. Turned engine off and back on and engines ran smooth but check engine remained on. Dealer said all spark plug way out of spec. (121K miles on car). Did the same thing after all plugs replaced. Tech advised of perhaps a deeper problem (cylinder 4 problem). The fact that when I restart the car it runs fine, gives me a feeling perhaps the problem is something electrical, like a sensor and not a mechanical issue. Any ideas?
Old Mar 18, 2021 | 04:44 PM
Default Re: Multiple Cylinder misfires - Check Engine
Some initial thoughts:. RCM, Fuel pressure
Old Mar 18, 2021 | 06:20 PM
You had several codes, if we do not know what they are we can offer no suggestions. The codes are the first things to study and correct.
A cylinder 4 code could be a coil problem. Swap it with another coil and see if the code moves with the coil.
If it was a plug problem then there would be a constant problem not an intermittent one. Do not trust a dealer their second language is lying with a straight face while they rob you blind.
Old Mar 18, 2021 | 08:18 PM
Dealer said ...
Any ideas?
Yea, stay away from dealers. ANY shop that has dealt with the M112 Mercedes engine knows far more about that car than the entire Chrysler corporate structure.
Additionally, without the code(s) that are setting off the check engine light, I have nothing to add.
droopaloop
May 8, 2020 02:21 PM
ggwersal
20
Feb 26, 2014 09:59 PM
jdokan
U.K.
May 7, 2010 05:45 AM
murtazanooruddin
17
Mar 4, 2009 12:33 PM
Stranded_2004
Apr 2, 2004 01:17 AM
