Whining Sound In Engine Bay
Old Apr 14, 2021 | 12:43 PM
Sexy Back's Avatar
Default Whining Sound In Engine Bay
I have a 2005 Crossfire Limited with 87K miles and recently noticed a whining noise coming from in front of the engine, more towards the alternator side (power steering pump pulley side is good). Sounds like a turbo is spooling up when I accelerate. Can be repeated when parked and revving the engine. I replaced the water pump and serpentine belt back in December. Just a slight leak from one of the top bolts on the water pump but that could be gasket issue or bolt is not torqued enough. I did notice the tensioner pulley assembly wiggles rotationally a bit while it is running. Could that be the issue or has it caused the alternator bearing to go bad? Should I replace the alternator and the tensioner pulley?
Old Apr 14, 2021 | 01:29 PM
JSK's Avatar
JSK
Default Re: Whining Sound In Engine Bay
That tensioner should have no movement. Replace it. Even if the noise is still there at least you didn’t waste any money.
Old Apr 16, 2021 | 12:14 PM
konstant1981's Avatar
Hello , i have this noise , maybe is the same
Old Apr 19, 2021 | 05:50 AM
Sexy Back's Avatar
Unfortunately no, my sound is like a higher pitch noise getting louder when you rev the engine. I order a new belt tensioner assembly and alternator over the weekend. Hopefully either one will help. Thanks for chiming in though.
Old Apr 19, 2021 | 09:15 AM
Take off the belt and check each bearing individually.
Old Apr 19, 2021 | 09:20 AM
Sexy Back's Avatar
Agree, several had mentioned that in older posts. So very odd to hear this high pitch sound and it gets magnified when you rev the engine. Will send update post soon.
Old Jun 2, 2021 | 12:12 PM
Daisyd's Avatar
Did you ever find your issue? I have to remove my belt today and check all bearings and pulleys. I hope you found your issue because this sound is annoying
Old Jun 3, 2021 | 05:57 AM
Sexy Back's Avatar
Yes I did find out the exact location of my whining noise and it ended up being the alternator bearings. So I had to replace it and did however replace the belt tensioner pulley and idler pulley first to rule them out. Both had significant wear so it was only a matter of time. The lower alternator bearing bolt was a pain to align so that was the only issue I had replacing that componant. Hope you were able to find your issue and fix it. It helps to have another person listen to all the pulley areas to narrow it down. Good luck!
Old Jun 3, 2021 | 10:55 AM
Daisyd's Avatar
Wow, thank you for responding so fast! I’m glad you found your problem! At first I thought it was my alternator in general but I haven’t lost power or anything so you give me hope to check my idler and the pullies (not sure if I spelled that right) thank you again! This sound is annoying hahah! You’re lucky you’re finished with hearing this sound! Have a beautiful day🦋
Old Jun 3, 2021 | 12:14 PM
Sexy Back's Avatar
Not a problem, that is what we are here for. My alternator was still charging fine but you could hear the whining noise closer to that side of the engine. It could be the water pump pulley bearing too. I did replace that in December too. So for me the only original accessories on the front of my engine are the power steering pump and AC pulley. If you take serpentine belt off, you should spin the Idler pulley first. If it continues to spin for a bit, then the bearing is bad. If it stops fairly quickly, then it is okay. As for the belt tensioner pulley, they feel gritty when spun tested. You will not be able to feel any difference in your alternator pulley if the internal bearings are starting to go bad. Let me know how you make out and good luck.
Old Jun 3, 2021 | 08:25 PM
Daisyd's Avatar
hello my friend^_^
I just checked everything and it all sounded great except my tension pulley. Holy moly it was super wiggly and noisy so I just ordered one $247 later🥺. It’s weird because the sound wasn’t even on that side so I’m not sure if the sound was just traveling to the side of the idler and alternator side. I tightened the idler pulley after putting it back on, put the belt back on and for some reason the whining sound is gone now. I’m still going to put my new tension pulley on since I’ve already ordered it and it’s really bad too. Thank you for teaching me how to check the pullies☺️ I also watched some videos and read some articles and they said everything you said so thank you again! I really appreciate you and how fast you responded. Hopefully when I get my new part I can finally play with my car again wahoo! Have a fun day!
Old Jun 4, 2021 | 03:36 PM
Originally Posted by Daisyd
hello my friend^_^
$247 for a tensioner pully assembly??? Did it come with a short block? Jeeze thats high... A quick example ( https://www.fcpeuro.com/products/mer...000970#fitment ).
Old Jun 4, 2021 | 04:37 PM
Daisyd's Avatar
omg $88!!! I wish🥺 my 2006 Car parts manual said my part # is 05096525AA and they are all above $200😔
Old Jun 4, 2021 | 06:04 PM
Cheaper still if you can get away with just changing the pulley.
Old Jun 4, 2021 | 06:37 PM
zip439's Avatar
That looks like a Chrysler part number; You should be shopping for a 2003 model year Mercedes SLK 320 if your car is a Limited Crossfire or a SLK 32 AMG if it is an SRT6 model
Old Jun 4, 2021 | 07:27 PM
Never buy a part with the Chrysler part number when an identical Mercedes part is available.
Old Nov 21, 2025 | 02:40 AM
Firebenz's Avatar
Mine started making that whining sound after I replaced the spark plugs. Sounds like it’s supercharged 🤣 don’t mind it too much but would like to repair it soon. Thanks for the info guys
Old Nov 22, 2025 | 02:04 AM
It could be the idler pulley which is easy to replace. I would recommend doing it before it fails. You could possibly shred your drive belt.
Here's my post of when I replaced my idler pulley, belt tensioner and belt. NOTE: My car is a manual, if you have an automatic, there is no shock attached to the tensioner.
LINK-Idler, Tensioner and belt replacement
Infinity
Oct 12, 2019 03:19 PM
Vipor3D
May 21, 2018 09:23 AM
Dementors
Feb 4, 2016 05:31 PM
scomer88
Oct 9, 2015 06:14 PM
tbudlee
Oct 23, 2014 10:02 AM
