Crossfire 04 ,automatic door locks
Old May 29, 2021 | 08:00 AM
zarcocruz1's Avatar
Default Crossfire 04 ,automatic door locks
When park I unlock the car everything is OK, then when when start driving only the passenger side lock automatically after you reach certain speed, not the driver door. But with the remote both doors work OK.
Also if I don't drive the car in 2 weeks the battery will be depleted,I have to use jumper cables after that no problems until 2 weeks later.
Any advise will be apprecited.
Old May 29, 2021 | 09:36 AM
Default Re: Crossfire 04 ,automatic door locks
The battery drain is most likely the siren under the cowl in front of the windshield. Use the search feature and you will get lots of insight.
Old May 29, 2021 | 10:56 AM
Read pizzaguys thread on finding the source of the battery drain. The siren has become a favourite scapegoat for any battery drain problems lately but is not responsible in most cases.
Use jumper cables as explained in the Owners Hand book or you could have major expenses.
Old May 29, 2021 | 10:58 AM
Doc78's Avatar
Hello the battery drain is most likely the siren great tutorial on here on how to remove it.
the locking issue is may be water in your trunk there is another great thread on here to check it then how to move forward. Start by sliding a piece of paper down beside the foam inserts in your trunk on the passenger side if it comes up wet then you know.
hope this helped
Old May 29, 2021 | 04:02 PM
zarcocruz1's Avatar
I'm going to try every advise, will come back with the results, thank you everybody for your help
freygreer
Mar 29, 2016 11:10 AM
green-ghost
May 31, 2010 09:07 PM
blackcrossfire07
Oct 14, 2009 06:27 PM
rcopeland
Dec 6, 2006 11:21 PM
polmstead
May 9, 2005 07:06 PM
