Crossfire top problem
Old Jun 29, 2021 | 06:58 PM
dave@customautotops.com's Avatar
Default Crossfire top problem
Hi, You have a great forum with much valuable information. I am replacing the top on a 2005 Crossfire. It looks to be a simple job if it worked properly. I'm pretty sure the top up switch over the passenger's head needs to be replaced, and the lift cylinders have to be sent out and rebuilt. I was able to unlock and release the rear bow with a 6 mm allen wrench. Using the tool that came with the vehicle, I tried to unlock the deck lid. It will raise up about an inch but not unlock, and spring back down. I followed the directions in the manual to relieve the hydraulic pressure, and also removed the #5 fuse. It seems to still be under pressure and won't release. I removed the torque bolts holding the lock mechanism, hoping it would make some difference, but no luck. Before I try anything else, I would like to hear from someone that has had a similar issue. Thanks, Dave, Brookfield, NH
Old Jun 30, 2021 | 12:20 AM
JSK's Avatar
JSK
Default Re: Crossfire top problem
I think you mean you can’t raise the tonneau cover. If so it won’t raise until you have fully raised the rear bow.
Old Jun 30, 2021 | 08:03 AM
Thanks for your response, I have lifted the rear top bow enough to allow clearance for the tonneau to open, the header is unlatched and raised from the windshield, but I'm not able to unlock the tonneau with the 10 mm tool. It seems like it is still locked. I'd like to do it manually to avoid causing any additional problems. It is possibly out of synch but I'm not sure. Dave
Old Jun 30, 2021 | 10:14 AM
When you unlatch the tonneau do you keep the wrench on the cam and hold it to the left as you open the cover? If I remember correctly if you just unlock it but not hold the wrench it just re-latches.
Old Jun 30, 2021 | 10:28 AM
JSK's Avatar
JSK
That is true.
Old Jun 30, 2021 | 11:03 AM
Maybe seeing someone do it will help.
Old Jun 30, 2021 | 08:34 PM
I think it may still be locked or somehow jammed. There is much more resistance when I turn the wrench, and it pulls right back down. I have a picture of the lock mechanism, with the cover removed. Is this how it's supposed to look in the locked position ?
Old Jul 1, 2021 | 11:28 AM
I gotta admit, that is such a closeup, I don't know what I'm looking at!
Is this the lid latch or the rear bow latch? And HOW did you get this photo!
Old Jul 1, 2021 | 12:08 PM
JSK's Avatar
JSK
I recently replaced all the cylinders on one of my roadsters, when I would open the tonneau I had my wife hold the rear bow up so I could use both hands, one to move the tool and one to lift the tonneau. I could not lift the lid without holding the wrench at its full travel point. I think you have the right idea, you just need an extra hand.
Old Jul 1, 2021 | 01:26 PM
Thanks Pizza Man, With the trunk open, the divider down, and the inspection cover removed ( 3 small screws ). There is no pressure in the system. It seems like the pin is not down far enough to actuate the switch. It seems like the tonneau is in the locked position and stuck or somehow jammed.
Old Jul 1, 2021 | 01:30 PM
Sorry, that is the lid latch; the top bow is unlocked and held up far enough for clearance, if it would open.
Old Jul 7, 2021 | 01:43 PM
lpw47lpw's Avatar
Watched all and can do top will go up after manually putting down but not down again only manually have not removed fuse 5 does car need to be running
since it works going up after putting down manually couls cargo sensor be bad?…heip
Old Jul 7, 2021 | 01:49 PM
Doc78's Avatar
The car needs to be running while doing the three recommended manual opens and closes.
I did 6 manual to make sure.
https://www.crossfireforum.org/forum...tml#post945786
This is a great thread for your issue very descriptive.
As far as whats going on with yours.
DO the windows roll down when you turn the d ring and push the top up?
If they do check the roof up sensor described in the thread listed above.
If not check the sensor in front of the passenger embedded in the windshield.
Hope this helped.
Old Jul 7, 2021 | 06:43 PM
THis is an easy one; either the divider ("cargo") sensor is bad (and it probably is) or the top open switch over the passenger's head is bad.
Gotta be one or the other. Open the trunk and make SURE the arm on the divider, driver's side, is pressing up on the switch arm.
Moondog
Oct 15, 2020 10:47 AM
FireTeach
Jul 31, 2020 09:41 PM
leroyvette
Oct 29, 2019 11:52 AM
jasonm
Sep 7, 2009 04:34 PM
