Difference between bad Camshaft and Crankshaft position sensor symptoms
Old Jul 14, 2021 | 08:43 PM
Bookio's Avatar
Default Difference between bad Camshaft and Crankshaft position sensor symptoms
What are the different symptoms between a bad Crankshaft position sensor and a bad Camshaft position sensor?
Thanks
Old Jul 14, 2021 | 10:15 PM
Doc78's Avatar
Default Re: Difference between bad Camshaft and Crankshaft position sensor symptoms
I'm a proponent of reading the codes stored in the computer via an OBD tool. The MB codes are more accurate and informative in my opinion. I found the below link for the MB P codes its a PDF.
https://www.crossfireforum.org/forum...p-series-2.pdf
Hope this helped.
Old Jul 15, 2021 | 10:57 AM
Deepsea21's Avatar
Symptoms are the same... No start although generally the crankshaft sensor goes before the camshaft sensor as it is located in a hotter area of the engine. Sometimes when the crankshaft sensor starts to fail the car will die while driving but then you'll be able to get it started again after it has cooled down. Crankshaft sensor is cheaper than the camshaft sensor. When you replace, go with Bosch... Not cheap crap that will fail right away.
Old Jul 15, 2021 | 02:15 PM
Ronman's Avatar
Thanks
Crankshaft sensor: Car will die randomly at red lights or stop sign. Then you will be able to restart it immediately or have to wait until it cools down. A check engine light sometimes will come on and store a code.
Camshaft sensor: Car will crank and crank and not start or crank for a while then start. Usually a check engine light will come on and code will be stored.
Old Jul 15, 2021 | 10:41 PM
Bookio's Avatar
Thanks everyone for the help and information.
Old Jul 16, 2021 | 01:33 AM
philosophico's Avatar
Ive only had my car die on me once from a fail crankshaft sensor and it was when I was merging on the hwy, glad I beat every and was able to merge before it died since I could coast to the emergency lane with no problem Since then though I usually get a check engine light for a bad crankshaft engine. My car eats them, I swear I change the thing once every 2 years, but my car is a DD.
Ive never changed my camshaft sensor since I owned this car, im tempted to just replace it anyway.
Old Jul 16, 2021 | 08:25 AM
Bookio's Avatar
Thanks. I’m going to get a spare of both sensors and a relay control module and keep them in the trunk.
Old Jul 16, 2021 | 09:15 AM
Doc78's Avatar
There is a great spare parts list on the forum. I would be sure to test that RCM before putting it in the trunk. People have gotten new ones that will not work. Tightend1 reworks them for a reasonable price. So you can get one cheap off ebay and send it to him for rework and then you know it works.
I placed a link to the spare parts list below it is a PDF.
https://www.crossfireforum.org/forum...rossfire-3.pdf
Old Jul 16, 2021 | 11:03 AM
RDC's Avatar
RDC
So my wife bought a 2006 crossfire 3.2 47000 miles. drove for one whole day and died on her and just would turn over and not start until it cooled down. Drove home and started looking on internet and found this site. Was a lot of help. Decided to buy new RCM and crank and cam sensor. Just to kill all birds one stone. Car would start and then just crank and no start. And then crank long time and try to start like the timing was off or flooding. Found out the crank shaft position sensor I replaced was Bosch and cam sensor was import direct. Changed to Bosch cam sensor and car runs like a champ. But now I have a high pitched whistle noise from behind the glove book when AC is on goes away when fan is on the dot . Button but whistles when in the O fan position. This happens when driving and you lift off the gas and RPMs are dropping back down. Replaced the AC vacuum valve and air filter and still has the whistle. Any help please thanks
lotsofspareparts
49
May 31, 2024 06:00 PM
roychez
15
Aug 31, 2022 01:11 AM
grburght
Jun 14, 2021 08:52 AM
Chrizar
Sep 13, 2016 07:10 AM
steevyn
Nov 11, 2012 11:30 AM
