What PS fluid?
Old Sep 28, 2021 | 09:00 PM
No704's Avatar
Default What PS fluid?
Have a small leak and need to top off. I’m sure I’ll be asking about hoses soon but haven’t had a chance to get into it yet!
Old Sep 28, 2021 | 09:51 PM
Default Re: What PS fluid?
Should be written on the cap : Pentosin CHF 11S
Old Sep 29, 2021 | 06:19 PM
SD Crossfire's Avatar
As mentioned above, also make sure you add only very little at a time or you can easily overfill, literally a shot glass amount of fluid was needed to get it from not showing on the dipstick to reaching the max cold reading. Though a small turkey baster should fix it should you overfill.
If you didn't know already, there is two ways to check the PS fluid level, either HOT or COLD based on the dip stick. Which has two hatches (min and max) for both cold & hot readings. Make sure you push in the dipstick/cap all the way in and screw it down before pulling it back out to get a proper reading on the level.
Old Oct 1, 2021 | 05:47 PM
No704's Avatar
Thanks all, I have a can and some 60ml syringes left over from working on the top system.
syfi
Mar 28, 2026 04:14 PM
Brian P
24
Aug 4, 2020 04:35 AM
tje275
Jul 6, 2018 08:21 AM
Dnivek
Apr 24, 2013 05:20 PM
SirFin
Dec 5, 2004 03:11 PM
