Need Help diagnosing no start
Old Oct 9, 2021 | 07:10 PM
dgolia1's Avatar
Default Need Help diagnosing no start
Could use a few extra set of eyes to look over current issues and advise
A few weeks ago my manual limited had the typical start then die immediately 3 times, then nothing. I've had the skreem/ecu sent out (came back with a clean bill of health), I checked the module in the truck for corrosion (nothing), plugged in my rcm for my srt6 (still won't start). My next steps are camshaft position sensor and crankshaft position sensor
Any other ideas???
Thanks
Old Oct 9, 2021 | 08:38 PM
Default Re: Need Help diagnosing no start
That is the signal that the SKREEM is telling the ECU to not allow a start. Did you send the keys in as well? They can't correctly assure you all is well without the keys, they must verify the SKREEM can read teh RFID chip in the key fob, because if the SKREEM can't read that code from the RFID chip in the FOB, this is exactly how it acts.
One reason for this to occur would be the O-ring around the ignition key, that black rubber ring has a loop antenna in it, that is how the SKREEM reads teh RFID chip in the key fob. I don't know that I've ever heard of that ring going bad, but I do know the wires from it have been found to be unplugged from the SKREEM - resulting in this issue.
Who checked the ECU and SKREEM? If they say they are OK, and it does not start, I"d be asking them.
Old Oct 10, 2021 | 10:29 AM
dgolia1's Avatar
Skreem, ECU, and keys were sent to Rob at Needswings and came back clean. I have confidence in that diagnosis. I'm trying to figure out what it could be next
I also have a spare antenna ring that I tried
Old Oct 10, 2021 | 11:17 AM
After disconnecting the battery, does it go three and nothing again?
Old Oct 11, 2021 | 10:09 AM
NeedsWings's Avatar
it is not going to be those, check my previous emails
Old Oct 11, 2021 | 10:10 AM
NeedsWings's Avatar
if they are used, they are suspect
Old Oct 11, 2021 | 02:41 PM
dgolia1's Avatar
After cleaning some of the fuses with sandpaper, she fired up
I'll provide an update if this is a lasting fix
Thanks guys
Old Oct 11, 2021 | 05:18 PM
Ronman's Avatar
Thanks guys
Which fuses did you sand?
Old Nov 6, 2021 | 08:42 PM
direwolf's Avatar
My money is on Fuse 37
5 Amp Beige -- Circulating Air. Instrument Cluster. Radio Frequency Remote Control. Residual Engine Heat Utilization
That little 5 amp fuse can turn your car into a no start paperweight
Old Nov 24, 2021 | 12:21 PM
dgolia1's Avatar
So far so good. I cleaned all the fuses under the hood - so no idea which one it was
Old Feb 13, 2022 | 11:26 AM
dshaw19013's Avatar
AGAIN… STAY AWAY from Precision ECU in Chicago!!!They are a SCAM and they will destroy your ECU if you send it to them. They do not reprogram the ECU as advertised, but they simply open the ECU and they add a bypass.
Old Feb 13, 2022 | 12:41 PM
NeedsWings's Avatar
parts received, we will get it sorted out
Paulo
Dec 15, 2022 11:40 AM
Mike_man458
Oct 10, 2020 11:48 AM
cammons
May 29, 2019 09:01 AM
Terry Moore
Oct 5, 2014 06:49 PM
piphpap3
25
Jan 20, 2013 04:35 PM
