Stereo and Trim removal?
Old Aug 13, 2005 | 01:37 PM
Scott_lmtd's Avatar
Default Stereo and Trim removal?
I went to my local Stereo place (Car toys) to have them pop the Stereo with the keys, and non of the keys they have work. They tried VW, Merc, BMW, everything in the set, nothing would grab. Anyone else have this problem, or is the Becker set that "special"?
My assumption is once the Stereo comes out you can access some screws or clips to remove the trim from around the rest of the console (A/C controls, control button group, silver trim) area? Can someone confirm that, don't want to pry something and break the trim.
Thanks
Old Aug 13, 2005 | 03:25 PM
XFire2465's Avatar
Default Re: Stereo and Trim removal?
Mercedes Radio Keys work. Make sure you have the turned the right direction. I think the hook goes outward.
Old Aug 13, 2005 | 04:38 PM
Scott_lmtd's Avatar
Thanks, they did, (so did I) actually tried both ways, they would never grab.
Found a Pic of them...
Old Aug 13, 2005 | 07:27 PM
chxf's Avatar
CyberGreg once posted in this thread on page 2 a picture of a universal removing tool. But I think your dealer should be able to order the 'Radio Removing Tool'. Ask him to check in his service manual.
Old Aug 13, 2005 | 07:42 PM
XFire2465's Avatar
That is the same keys I used. Maybe they tried to stick something else in there prior and bent the catches inside.
Old Aug 13, 2005 | 09:36 PM
chxf's Avatar
Well, if that's the case ... good luck!!!
This happened to me once in a former car. I had to remove almost the whole trim to access the radio from behind, bend/brake the radio casing retainers. Awful work!
Old Aug 13, 2005 | 10:12 PM
CyberGreg's Avatar
The Becker manual has a good guide, here's some pictures...
After inserting the tool you have to pull away from the radio like toward the doors. This compresses the spring clips holding the head unit in.
File Type: png
File Type: png
Old Aug 13, 2005 | 10:16 PM
CyberGreg's Avatar
Originally Posted by Scott_lmtd
... My assumption is once the Stereo comes out you can access some screws or clips to remove the trim from around the rest of the console (A/C controls, control button group, silver trim) area? Can someone confirm that, don't want to pry something and break the trim.
Thanks
Yes, you will break stuff if you don't remove the head unit first. There are at least 4 screws (from memory), two just under the A/C controls (behind the head unit) and two in the upper vents. You have to remove the vents first.
Old Aug 14, 2005 | 12:48 PM
Scott_lmtd's Avatar
Thanks, appreciate the replies.
Old Aug 15, 2005 | 05:24 PM
stryfox's Avatar
I got keys, wiring adaptor and antenna adaptor from crutchfield for free, when i ordered my new headunit. The keys came with instructions, slid keys in radio and it came out, took 10 sec. Kinda scary actually.
Good luck.
Old Aug 17, 2005 | 06:33 PM
italianmafia03's Avatar
I believe the VW keys work as well. Becker makes a lot of stereos for german cars.
Old Aug 17, 2005 | 07:32 PM
MAYAman's Avatar
I got the keys from Crutchfield for $15...rip-off, but they did the job. And yes, the VW keys do work.
Old Aug 21, 2005 | 12:30 PM
Scott_lmtd's Avatar
Thanks. I called Becker, ordered the keys, $7.36 including shipping/handling. 3 days later radio is out. Who knows, maybe we didn't push the other keys in all the way, but the Becker keys took all of a few seconds.
Old Aug 21, 2005 | 08:00 PM
It took my stereo guy no more than a minute to completely remove the stock HU. Pop the keys in and unplug the wires and its DONE!
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
o55ie18
Oct 5, 2015 05:50 PM
brandoni
Sep 30, 2015 07:48 PM
55chevy
Sep 13, 2015 07:38 PM
