Leaking Oil Filter
Old Feb 22, 2022 | 03:59 PM
Johnny Versatile's Avatar
Default Leaking Oil Filter
Hi Folks; Just noticed a large oil leak when warming my car up. It turns out I have a leaking o ring seal on the top of the filter housing. Anybody have a mercedes part # for the o ring or the housing as it may be cracked. It appears the o ring has just stuck out a bit from the housing. Push it back and it won't stay. Thanks. Mercedes is no help locally on this one.
Old Feb 22, 2022 | 04:03 PM
Default Re: Leaking Oil Filter
Go get a new oil filter, they have the O-rings in a little bag in the box. And WATCH IT when you put the new one on. In every instance I've seen, the O-ring leaked because it was improperly set - it goes not in the TOP grove of the carrier, but the next one down. Most filters have a little diagram in the box showing you where that top O-ring goes.
Old Feb 22, 2022 | 04:08 PM
Thanks. I figured that's what I did. When I went to put it in the lower grove, I find it had been stretched. I did the oil service in the fall and did a new filter oil etc. Up to now I didn't notice the leak and it collected in the pan. I hoped I could just buy an o ring. I'll just order another filter. When it comes in, I'll go to Rubberline, get a matching o ring from them and then replace it. Thanks.
Old Feb 22, 2022 | 04:38 PM
CROSSFIRE OIL FILTER CHANGE
Usually you will get 5 o-rings with a new filter.
4 of them go with the filter as shown here.
The 5th one is for the dipstick.
[img]file:///C:/Users/grndp/AppData/Local/Temp/msohtmlclip1/01/clip_image001.png[/img][img]file:///C:/Users/grndp/AppData/Local/Temp/msohtmlclip1/01/clip_image001.png[/img][img]file:///C:/Users/grndp/AppData/Local/Temp/msohtmlclip1/01/clip_image003.jpg[/img]
Old Feb 22, 2022 | 04:42 PM
I always wondered where that 5th one went. Just getting in to my 4th year. Already ordered a new Mann fleece filter. Did all the "must do's on the car in the first year and only been enjoying it for the last 2 years. New set of Michelins in the spring. That should do it for a while!
Old Feb 22, 2022 | 05:18 PM
I"m going to disagree with Z, I don't do that often, but this time I think I must.
From Benzworld:
The 4 red arrows indicate the o-rings everyone changes. The stem and the oil filter cap are detatchable but hard to reassemble. There is a valve located where the 2 parts detach (pink arrow) it has a o-ring on it (green arrow). That is the one you have left over.
Over the course of 12 years, 120,000 miles and three Roadsters, I've replaced that o-ring one time. That arrow looks violet to me, not pink.
Old Feb 22, 2022 | 05:49 PM
I believe PIZZAGUY is correct. I was wondering where an 'O' ring was on the dipstick.
Old Feb 23, 2022 | 07:54 AM
waldig's Avatar
long ago i suggested the smallest used o ring for the dip stick to keep it in better and to prevent blowout of oil during high rpm operation. Woody Used to autocross b4 covid hit.
Raindem
15
Jul 8, 2017 01:11 PM
lildaddym
Mar 4, 2014 07:43 PM
315er
Sep 24, 2010 07:42 PM
pxfire
Feb 22, 2009 04:58 PM
doublediz
Jan 10, 2008 04:36 PM
