Two injector code
Old Feb 26, 2022 | 06:46 PM
Ant92994's Avatar
Default Two injector code
Hi I’m at my wits end at the moment. I’m having two misfire codes and two injector codes on the same cylinders. I swapped everything already. If I go to the ecu c4 connector where all the fuel injector wires go into and wiggle it the car will literally shut off. Is their a way to fix the pins in there or do I need a new harness ? Has anyone experienced this. The car drives .
Old Feb 26, 2022 | 07:46 PM
Default Re: Two injector code
First of all, why not tell us what the codes are? You are making us guess - that' wastes everyone's time.
Second, I"m having a hard time that connector C4 would be the issue. But then, I've never wiggled that connector to see what will happen.
Old Feb 26, 2022 | 08:00 PM
Ant92994's Avatar
It was c4 connector . Had to remove the external housing with the clip on it and connect it that way check engine light immediately off. I was more concerned about replacing it or a fix not a diag as much. So if anyone is ever throwing injector codes and misfires and you’ve already swapped everything and double checked the wires. Make sure your getting a good connection there.
aaronmb52
Jun 2, 2021 09:42 AM
d2_mcgill
30
Sep 15, 2018 12:35 PM
khuck1
Jul 24, 2017 04:13 PM
Hawkske
Jun 3, 2016 10:14 AM
Goldwing
May 23, 2009 11:44 AM
