Help needed
Old Apr 9, 2022 | 04:43 PM
Default Help needed
I have looked at the service manual and can't find anywhere that tells how to remove the door lock. I only need to remove the part you put the key into to unlock the drivers door.
Thanks
Old Apr 9, 2022 | 09:35 PM
Default Re: Help needed
First you must remove the entire door handle. check my pics here for the lock. Door lock - exterior by James1549 | (crossfireforum.org)
Old Apr 9, 2022 | 09:39 PM
Here is better: Exterior driver's door lock? - CrossfireForum - The Chrysler Crossfire and SRT6 Resource
Old Apr 10, 2022 | 10:00 AM
Thanks James, are you saying the entire lock and handle must be removed to get the lock itself off? My key blade is bad and I was told if I send them the door loch cylinder they can use that to make a new blade.
Old Apr 12, 2022 | 06:54 AM
bc75's Avatar
Couldn't you just use the one from the glove box?
Old Apr 12, 2022 | 09:46 AM
The place making the key said no.
Old Apr 12, 2022 | 09:48 AM
It would be to easy to steal a car if you could easily take out just the lock cylinder.
Old Apr 12, 2022 | 09:50 AM
Ronman's Avatar
It is in the manual where they tell you how to remove the door lock actuator on the driver's side and on a post somewhere here. Your remove some of the weather stripping behind the door and there is a hole and you can see a screw in there. Then you need a long 4mm allen wrench and while you are removing the screw you need to be pulling on the lock cylinder from outside door and eventually you will remove it.
Old Apr 12, 2022 | 03:54 PM
Thank you.
Davidod
Jun 14, 2021 12:43 PM
JSK
Apr 30, 2021 01:54 PM
drummertom
May 17, 2019 11:26 AM
freygreer
Mar 29, 2016 11:10 AM
oceansideaddict
Mar 20, 2011 07:21 PM
