Electrical problems, brakes, brights,
Old Jun 8, 2022 | 07:48 PM
EonsofDeathsToll's Avatar
Lightbulb Electrical problems, brakes, brights,
Hello, I just bought my dream car from highschool back in 2008. 114k mile crossfire. It's the v6, manual, solid body. It has one huge problem, the brake lights, brights, cruise control do not work! When I reset the dash lights by turning the wheel left, right and center for abs and then press the brake pedal, the light comes right back on. I'm thinking replace the entire damn fuse box behind the driver's side door where the light switch control is. Any ideas on where to start?
Old Jun 8, 2022 | 11:21 PM
Default Re: Electrical problems, brakes, brights,
I just bought this great car. I'm trying to troubleshoot an issue I'm having, and trusting others here have some experience with it before I go ***** Billy and buy random things.
Issues are
-no brake lights
-no cruise control
-dash light for esp? the braking system! I reset it by turning the wheel left right and mid, then when i press it it just comes right back on.
I'm thinking buy a whole new fuse module doohickey on the inner driver door.
I checked the fuses everywhere there fine. Unless I missed some somewhere else.
Any help would be greatly appreciated!!!! Trying to find info on this site, any good thread with the answer?
Old Jun 9, 2022 | 12:30 AM
Issues are
-no brake lights
-no cruise control
Brake lights, cruise control and maybe ESP, sounds like brake switch to me..Others may or may not agree.
It is a cheap part and will not break the bank, just get the correct one.
Old Jun 9, 2022 | 12:55 AM
How do I make sure it's the correct one?
Old Jun 9, 2022 | 10:33 AM
zip439's Avatar
The Mercedes part number is 001 545 64 09. You can use the search box in the upper right of this website to get more info; Just type in the part number. If you buy electronic parts at Autozone you are asking for trouble.
Old Jun 15, 2022 | 04:14 AM
I just purchased and installed brake light switch, middle light now comes on. Bas esp comes on still after reset. All lights have been replaced in the rear. All fuses replaced. Waiting on yellow fuse under hood driver's side to arrive for replacement. Just found a leak in rear differential now. Really don't want to dish out cash at mechanic. Found one who works on Mercedes, 200 a shop hour, my god. I drop it off next week. Hoping this fuse arrives and is the fox though. About to check relay connection at light switch, maybe wiring is loose. Any ideas from here? The 155 dollar inspection fee would cover a new part. SMH.
Old Jun 15, 2022 | 07:20 PM
Deepsea21's Avatar
I think you have separate problems going on that are not related. The brake lights and no high beams are separate problems from the BAS/ESP lights. Start the car, drive it around, without re-setting anything, take a pic of your dash and post it so all can see what indicator lights are on.
Old Jun 16, 2022 | 08:47 PM
Then burnt bulb indicator goes on and off on ride as well. Just replaced giant yellow fuze under hood, driver's left side.
I have a hundred dollar scan tool, only says 02 sensors. Cats are deleted. No other codes are being thrown. I have seen posts regarding a special 0B2 tool to use and not any regular one. I don't know if this is true. Just took off dash again to reinstall the brake light switch. I'm thinking 🤔 ..maybe I should check all these electric connections, I do have a multimeter, but am not familiar with using that well.
Now the right blinker is acting up. Lordy! Sometimes it doesn't work.
Old Jun 17, 2022 | 12:02 PM
Here are the abs codes it's throwing inside.
Codes of abs system. Where should I start? I need to fix the break lights first.
Old Nov 12, 2022 | 09:42 AM
skarlet's Avatar
So how do you replace the brake light switch, I am trying to get to the brake pedal to replace my switch I am assuming it is in the normal spot above the brake pedal. I cannot figure out how to remove the cover under the dash. Any help would be appreciated.
Old Nov 12, 2022 | 09:55 AM
Index of Crossfire problems and repairs - CrossfireForum - The Chrysler Crossfire and SRT6 Resource
Old Nov 12, 2022 | 11:35 AM
If you go to the "Sticky Key" thread and download the PDF, the first thing it explains is how to get thru the underdash disassembly.
Old Nov 12, 2022 | 11:40 AM
skarlet's Avatar
I have gone thru this multiple times and maybe I am missing something, but I do not see anything that helps. People say they have replaced the brake light switch, I just cannot figure how to get to it by the brake pedal. If the information is in this list could you direct me to specifics. rhanks
Old Nov 12, 2022 | 03:52 PM
mikemadeit94's Avatar
Super simple, just remove the screws basically on the bottom driver side panel underneath the steering wheel and remove that shroud. You’ll have the access you need.
Johnny24
May 7, 2019 10:59 PM
Bay Cruise
Jul 17, 2014 01:23 AM
kevtamus
Sep 7, 2011 09:58 PM
Hipower
Aug 26, 2011 07:19 PM
dkendall
Aug 19, 2010 10:02 AM
