EGR Tube Stuck
Old Jul 9, 2022 | 04:29 PM
X-fired's Avatar
Default EGR Tube Stuck
I'm attempting to remove my EGR valve but the EGR tube is stuck in the EGR assembly. I've watched a couple of videos and once the nut is removed, it should slide right out. I can rotate the valve and tube a few degrees but discovered that the collar B is stuck in the fitting C and the rotation is happening between A & B. I put a couple of drops of penetrating oil between B and C but it's not budging.
Any advice, other than just keep wiggling and pulling on it?
Old Jul 9, 2022 | 04:35 PM
zip439's Avatar
Default Re: EGR Tube Stuck
Place a bit of wood between the flex tube and any solid part of the car, then tap the EGR value; Or twist the EGR value and hold the tube/ collar. It should come loose.
Old Jul 9, 2022 | 04:53 PM
X-fired's Avatar
Bam! I rapped on it gently before but it was the block of wood that made the difference. Seems obvious now.
Thanks.
Old Jul 9, 2022 | 06:49 PM
X-fired's Avatar
I replaced the EGR because of the CEL and P0400 code. After a short drive, the CEL is still on. Do you know if it takes more driving to reset (assuming I fixed the problem) or do I need to have a shop reset it?
Old Jul 10, 2022 | 08:11 AM
zip439's Avatar
Generally, EGR value do not go bad, but right next to the EGR is a plastic solenoid that may not be functioning properly. This may help: CLICK.
Old Jul 10, 2022 | 08:33 AM
zip439's Avatar
I would think the P0400 code will clear itself with driving, but who ever gave you the P0400 code should also be able to clear it. You could try an auto parts store. Their scan tool should be able to clear that code.
Old Jul 10, 2022 | 12:40 PM
X-fired's Avatar
I replaced the EGR valve assembly that included a new solenoid. I got the code read at Advance Auto who says they're not allowed to do a reset. I'll give a few drives and see how it goes.
Thanks.
marksill
Aug 22, 2016 11:25 PM
Sarina
Aug 28, 2011 06:42 PM
VIPER0076
Jun 7, 2011 06:40 AM
Aullios
Apr 26, 2011 09:02 PM
gsxrat12
Apr 20, 2008 05:16 PM
