Engine Fan - A/C issues
Old Sep 13, 2022 | 04:39 PM
Chief400's Avatar
Default Engine Fan - A/C issues
2007 Crossfire coolant light comes on and cooling fan, air cond, stops and it blows the 50 amp fuse by the battery. HELP
Thread Title edited to reflect content. - Pizzaguy
Old Sep 13, 2022 | 05:04 PM
Default Re: 2007 Crossfire
I THINK what you mean (it's not a good idea to post a question asking for technical help and not be clear) is this: "THe fuse blows, so the light comes on and the fan stops running".
Because, if that fuse blows, the fan controller has no power - so you get no fan and the light comes on because the ECU can tell the FCM (Fan Control Module) is in trouble. CERTAIN FCM messages will cause the ECU to cut out the A/C to protect the engine, so that is also explained.
WHat can blow that fuse? Two obvious suspects: The fan motor and the FCM. It is not altogether easy to tell which it is, you can try disconnecting the fan from the controller and seeing if that stops blowing the fuse, but be prepared to replace both. Now, this is an electrical problem so if you take it to ANY garage or dealer, they will replace one or both items as well . So, save some money, order both and put them in yourself, it's super easy.
If you take it to a garage, expect to pay $400 to $700 for this fix. YOu can order a fan module for under $200 and a fan motor assembly for around $150.
Old Sep 13, 2022 | 06:54 PM
Chief400's Avatar
Default Re: Engine Fan - A/C issues
Thank you very much, yes the fuse blows. I have a new fan and Im going to change it and check the fuse. Again thank you
Old Sep 27, 2022 | 02:40 PM
Chief400's Avatar
OK replaced the cooling fan with a new one tested fan before putting it on and it worked. now the cooling fan will no come on even when the air cond. comes on. the fuse is good did not blow.
Old Sep 27, 2022 | 10:00 PM
Shanerussell's Avatar
Hey guys just read up on that issue. I just posted a part out of a 04 xfire. An I can save you half the costs if you like to buy the OEM parts from me. I can assure u that they worked properly and I will put a quarantee on the parts I pull off my old beauty. I'm shanerussell 272-772-0305
Thanks again guys u all helped me when I was in need
SoftballJunnkie
Apr 3, 2011 01:50 PM
SoftballJunnkie
Mar 31, 2011 08:15 PM
Jesda
Apr 1, 2009 05:51 AM
kingkub57
Jan 20, 2009 11:13 AM
danny d
Jul 29, 2004 04:40 PM
