Head gasket
Old Feb 23, 2023 | 08:13 PM
slyfox1812's Avatar
Default Head gasket
Hello. Does anyone know where I could find a head gasket kit, that would have gaskets for both sides, and the intake? Also, I've found a low mileage engine for around 500 dollars or so. Would it be cheaper to put in a different engine or to just replace the head gaskets
Old Feb 23, 2023 | 10:43 PM
philosophico's Avatar
Default Re: Head gasket
It would be cheaper to drop in another motor honestly. Your talking about a semi engine rebuild if doing a headgasket plus you'd need to send the heads off to make sure they're not warped.
You can find headgaskets and everything else you need at fcpeuro. https://www.fcpeuro.com/Mercedes~Ben...=10&d=16734&v=
Old Feb 24, 2023 | 03:49 PM
slyfox1812's Avatar
That's sort of what I figured, the engine has some scoring in the cylinders and has over 200k on it. And I pretty sure the last owner was not very kind to it. Where would someone find procedures to pull the engine? I've only pulled one other engine, and it was on a pt cruiser when I was in college, so I don't think it'd be smart to do it without some kind of instruction
Old Feb 24, 2023 | 04:55 PM
It's pretty straight forward. Just take pics with your cell phone as you remove the old one. You might try a search on U-tube? It would be pretty much the same as a Mercedes SLK 320.
Old Mar 1, 2023 | 05:18 PM
slyfox1812's Avatar
I've done some more research and as long as the head and block aren't warped it would be cheaper to just replace the head gasket. Coolant hasnt leaked into the oil. Its just leaking compression. Im gonna pull the heads and check before I buy anything just to be sure. What else should I be checking when I do pull the heads? How much scoring is acceptable, and how do tell?
Old Mar 2, 2023 | 10:13 AM
dcskmail's Avatar
Engines here: use back arrow for different years https://www.car-part.com/cgi-bin/sea...erPage=1&iKey=
Old Jun 12, 2023 | 01:45 PM
slyfox1812's Avatar
I just wanted to post and update on this thread. I've gone the route of pulling the heads, I found that it is actually cheaper then replacing the engine. I'll be spending a couple hundred to maybe a thousand or a little over. Which Is much better than the 5k I was quoted to do the engine, most of which is parts cost, considering I work at the shop and would get a hefty discount on the labor. I would do it myself but I would still.be spending close to 4k on parts, not to mention equipment I'd have to buy. Overall I've found in my situation it's better to just do the head gaskets
xguy13
May 5, 2017 02:30 PM
hayirichie
May 10, 2014 03:30 PM
oojacoboo
Mar 5, 2014 09:17 PM
simkard
Nov 29, 2013 07:36 AM
dinasrt
Aug 9, 2011 12:32 AM
