Spare RCM and BCM
Old Apr 14, 2023 | 07:26 PM
Default Spare RCM and BCM
Last year I thought it might be a good idea to make sure the spare RCM and BCM worked so I installed them.
They worked fine so I left them in, the originals are in the trunk where the spare were.
Both were used items, the RCM cost me $45 about fifteen years ago, I had soldered the three usual points and inspected it for burnt contacts.
Old Apr 14, 2023 | 07:46 PM
Default Re: Spare RCM and BCM
OK, so the CLP/SSM is the same in the Coupe, the Roadster and in the SRT Coupe and SRT ROadster.
And the RCM is the same in all the cars.
But what about the BCM? Are there variations of BCMs?
Old Apr 14, 2023 | 08:44 PM
cruisewoodward's Avatar
Where is the best place to pick up a spare RCM and BCM for a 05 limited?
Old Apr 14, 2023 | 09:05 PM
Yes, they are model specific and probably the year specific. No programming required, so apart from the model requirement they are plug and play.
Old Apr 14, 2023 | 09:10 PM
I got both of mine on eBay. I would suggest at least a visual inspection for the RCM, better yet a running test and a running test for the BCM. They both just plug in.
You don’t want to have non running spares when you need them.
Old Apr 15, 2023 | 09:26 AM
bluecoupe's Avatar
Yes, they are model specific. No programming required, so apart from the model requirement they are plug and play.
So, 6 specific BCM's for the NA market. Base/SE Coupe, Base/SE Roadster, Limited Coupe, Limited Roadster & SRT6, SRT6 Roadster. I'd expect other variants for UK, Aus, Europe etc.?
Old Apr 15, 2023 | 11:29 AM
Stupid question whats "RCM" stand for what cntrl module?
I take it "BCM" is body cntrl module?
Old Apr 15, 2023 | 11:38 AM
tighed1's Avatar
Relay Control Module
Carry a spare and get your original refurbished. Not only will the three bad solder joints be redone, other weak solder joints will be done.
The four main relays will be replaced AND the Me So Horny mod (horn works without the key) will be done!
Currently $52 with return shipping in the USA. Email tighed1@hotmail.com for the details.
Old Apr 15, 2023 | 05:42 PM
Maybe one more, the 2004 was slightly different from the others, it was not a Limited. Get the model and possibly the year matching your car.
Old Apr 15, 2023 | 06:21 PM
bluecoupe's Avatar
Dave, I thought about the 2004 also. I think the only difference you might consider is the self dimming rear view mirror and I don't think it would involve the BCM, but I could be wrong.
Old Apr 16, 2023 | 05:22 PM
Hi There! Sorry I'm a newbie owner I have an 2005 Limited Coupe.. When I looked on Ebay for a spare BCM They don't list which model and year they came from...So how am I supposed to know which one to purchase? Is there a part # to look for?
Just so I understand a bcm that came off of a 2005 base coupe won't work then right?
However a RCM off of any crossfire will work?
Sorry for all the questions.
Also wheres the bcm located on the car?
Thanks and sorry for all the questions
Old Apr 16, 2023 | 06:02 PM
BCM and RCM are in the box next to the battery. Every RCM in all Crossfires, SLK320s and SLK230s are the same, cept the SLK230 RCM is about $45 cheaper but has all 15 amp fuses, one of our fuses has to be 20 amp - so I ordered an SLK230 RCM and transplanted the fuse.
BCMs dont go bad, I'd not concern myself with the BCM unless it is proven the BCM is bad. And Iv'e been here since 2009 and can think of maybe ONE BCM that failed.
In the SLK230, the yellow fuse is blue, our cars need a 20 amp (Yellow) fuse, there is no other difference in the RCMs between the '320 and '230.
Old Apr 16, 2023 | 06:14 PM
Thank you Pizza guy for the information I must say man I love this site
Have a great rest of your weekend!
Old May 7, 2026 | 09:51 AM
Stefy110's Avatar
Hi All,
I just bought a brand new SLK 230 RCM, part no: 170 545 02 05, for my uk 06 crossfire roadster. Changed the blue fuse (closest to orange one from 15amp to 20amp) and car still not starting. Even with fuses swapped to original, still no start. Is this the wrong part?
Old May 7, 2026 | 01:34 PM
zip439's Avatar
I believe that is the wrong part. The correct Mercedes number is 170 545 03 05.
However, what many have used here in the USA is Standard Brands relay Ry 1562; That is the correct replacement for a Crossfire and the Mercedes SLK 320.
When looking for the Standard Brands relay for a 2003 SLK 230 the number referenced is Ry 1739. Which indicates to me a different relay requirement.
After I dug deeper at the Standard Brands website it lists the Ry 1739 for both the SLK 320 and the SLK230, So apparently the two are indeed interchangeable.
It would be best to start a new thread and tell us exactly what is happening with your car. Does it turn over when you try to start the car or nothing at all ? What happens after you relax the key one notch counter clockwise from the full start position and let it there for one minute; Will the fan start up to high speed ? etc the more info we have the better we could help.
Old May 7, 2026 | 02:55 PM
Yep, more info needed.
joeyav
Jun 12, 2023 11:33 AM
ZERACER
Nov 25, 2021 09:54 AM
GraphiteGhost
Nov 16, 2020 08:52 PM
shaag78749
Dec 16, 2018 10:13 PM
