Crossfire Key Diode
Old Aug 12, 2023 | 03:15 PM
magnuman's Avatar
Default Crossfire Key Diode
As previously posted i am having trouble with my key and progrqamming.
can you look at the video of the diode lighting up.
Both of my keys look exactlty the same when the lock/unlock button is pressed.
It looks like on half the diode is lighting up.
Could this be the problem?
Or is this normal?
https://www.dropbox.com/t/Jt4U8QBOsAzp5mwj
Old Aug 12, 2023 | 05:11 PM
Default Re: Crossfire Key Diode
Or is this normal?
That is the same as mine and I have no trouble.
Old Aug 12, 2023 | 05:31 PM
Or is this normal?
The LED is essentially meaningless. The LEDs in my two FOBs have never worked, they are simply an indication that the remote board is powering up, which is nice, you know that your batteries are good and inserted properly - but not the LED is simply an "on indicator". Nothing more.
Old Aug 12, 2023 | 08:09 PM
magnuman's Avatar
Thanks Pizza Guy, although it would make sense that if th diodes were not working it might give you an indication of no power or something wrong.
I spoke with Josh and he still insists its not an issue with the SKREEM
I would gladly pull it out and send it to him.
I pulled my RCM today and it looks as new.
All solder joints, relays look great and no scorching at all.
This was Josh's last instruction.
I have ordered new pump to install.
"Disconnect the alarm and try a different locking pump. The SN line for lock/unlock confirmation via RF is not the same SN line that is used for the center console button. I’ve seen this a number of times. It is possible that your fob rolling code has become corrupt. If that is the case, there’s nothing you can do. However, I’ve only seen a very small number of people have that happen. Let alone two at the same time. You’re problem is wiring/mechanical"
meh03
Mar 30, 2023 07:14 AM
Padgett
Jan 24, 2023 06:02 PM
dj94
Aug 27, 2016 01:30 AM
NeedsWings
Mar 31, 2009 07:38 PM
