Input needed
Old Oct 19, 2023 | 04:35 PM
Default Input needed
The car is not local but is showing codes PO444 and PO141. Any thoughts on what to check or ???
Old Oct 19, 2023 | 10:38 PM
Default Re: Input needed
I don't know the name of it but it has a elect plug on it with a 90* turn vacuum line on one side and a clamped vacuum line on the other it is located under hood drivers side next to shock tower
replace that,,, P0444 gone and car will run better. jim
edit: i assumed you changed the RCM and you still had po444 , thanks Mark sometime i assume too much...
Old Oct 20, 2023 | 12:01 AM
P0141 is the heater trouble code for bank 1, sensor 2.
P0444 is an indication of evap issues.
The common thing between them is they are both powered by pin E5 from the RCM. I'd suggest putting your spare RCM in and seeing what you have after that. If this person is one who still has no spare RCM, they should order one today.
OR, they could waste tons of time and money 'troubleshooting'.... Owner's choice. But I hate wasting time, so I have a spare RCM.
renala3
Aug 1, 2019 04:56 PM
housebg
Jul 20, 2016 11:15 AM
scomer88
Mar 5, 2013 11:54 AM
dennisoates
Oct 5, 2011 03:10 PM
murtazanooruddin
Oct 21, 2009 09:32 PM
