Error code 52 and will not start
Old Nov 12, 2023 | 03:16 PM
klong's Avatar
Default Error code 52 and will not start
First time I’ve ever had a problem with my 05 SRT6 in the 14 years that I’ve owned it; drove it to NC (from NE GA - about 6.5 hours each way), and an error code of 52 popped up on the way home.
Went to start it today to look into a light out and no go - car will not turn over. Everything comes on, battery voltage is good (replaced last year), etc. Tried starting it in Neutral and still no go.
Any suggestions?
TIA,
KevinL
Old Nov 12, 2023 | 03:59 PM
mikemadeit94's Avatar
Default Re: Error code 52 and will not start
Any suggestions?
TIA,
KevinL
Not sure what error code 52 means, but a super common issue is RCM related. There's multiple threads on how to repair it, its usually 3 bad solder joints, also when you're in there make sure your relays are clean and not sticking (youll see burnt residue if they are just carefully disassemble and sand down.
Old Nov 13, 2023 | 02:53 PM
klong's Avatar
Update: car started today - all I did was put a little WD40 in the ignition on the chanc3 that it was a sticking tumbler. No issues except the 52 error code now.
Old Nov 13, 2023 | 03:21 PM
Where do you see a 52 code? If it is where the odometer is it means you are 52 miles over your oil change time.
Bob54
Aug 5, 2023 06:08 PM
jasonk931
Mar 25, 2022 06:22 PM
Buck62
Mar 19, 2022 04:07 PM
Bulldog
43
Dec 15, 2017 03:39 PM
Mobilemac
Sep 5, 2012 08:11 PM
