Central locking vacuum pump not working with key
Old Nov 19, 2023 | 03:10 PM
JohnMcV's Avatar
Default Central locking vacuum pump not working with key
Forgive me if this exact problem is discussed elsewhere.
Both FOB keys now won’t lock or unlock the doors. The car lights flash like they used to but there's no noise or results. When I start to drive, the doors and rear hatch lock themselves as they should and when I stop and open either door, they all unlock. I removed the passenger side trunk panels and all looks clean and new where the little hoses travel and no apparent water damage. I'm about to buy a used (with warranty) vacuum pump and do a swap. Should I just go for it, or is there another potential problem? Coincidentally, this problem started when I had the rear shocks repaired.
Thanks!
John
Old Nov 19, 2023 | 03:12 PM
Default Re: Central locking vacuum pump not working with key
When were the batteries last replaced in your key FOB?
Old Nov 19, 2023 | 04:42 PM
JohnMcV's Avatar
I just changed the battery in one of the FOBs, but I don't know how long I had those spare batteries.
Is it possible that the battery in the FOB is strong enough to cause the lights to flash on the Crossfire when I press the key but not strong enough to trigger the door locks?
Thanks,
John
Old Nov 19, 2023 | 06:31 PM
mikemadeit94's Avatar
Thanks,
John
I just had a mess with my locking unit finally got it worked out in a separate thread. Stupid question, but I did it... did you replace BOTH batteries?
Old Nov 19, 2023 | 06:35 PM
JohnMcV's Avatar
Yes, I replaced both batteries and can see the light flash inside the key when I press it. I'm going to inspect the harness connections on the vacuum pump and try spraying some contact cleaner in there this weekend. If that doesn't do it, I don't know what to do except buy a new/used vacuum pump and swap it in. I've had the Crossfire coupe for over 10 years.
Thanks,
Old Nov 21, 2023 | 06:45 PM
JohnMcV's Avatar
Problem solved. I noticed that the interior light wasn't working and that someone else on the forum suggested that checking and replacing fuse #9 might solve both problems. And it did. Thank you zip439!
RougeXF05
May 27, 2021 07:58 PM
AlexParra
Jul 13, 2020 09:06 PM
Spooky13
Aug 4, 2017 07:25 AM
dj94
Aug 27, 2016 01:30 AM
Drew08
May 22, 2016 02:34 PM
