Quick Transmission Question
Old Mar 3, 2024 | 09:22 PM
racerherbie's Avatar
Default Quick Transmission Question
Still going through my lower mileage (76K) 2004 Crossfire I picked up this winter. The prior owner changed the transmission fluid and the filter but did not change the Transmission Electrical Connector. Looks to be slightly leaking. Can I change out that connector without having to drain the fluid?
Old Mar 3, 2024 | 09:39 PM
Default Re: Quick Transmission Question
I have read in the past that if you jack the car up on right side only, you will only loose a minimum amount. James
Old Mar 5, 2024 | 07:40 AM
xintersecty's Avatar
Yes, I just replaced that connector many times with my recent unrelated to the connector transmission issue.
Short procedure:
1) remove the shield
2) twist the lock to unlock the connector.
3) use a socket to loosen the bolt on the inside
4) pull out the connector.
5) use a good connector and make sure all the molding is clean and no left over plastic (buy one from FCP Euro not amazon)
7) make sure you have two O-rings, and replace. This will take some pressure to push in place, the locking tab must be down
8) tighten internal bolt
9) install connector and lock
10) reinstall heat shield
Old Mar 13, 2024 | 11:15 PM
bc75's Avatar
Agree I bought my first one from amazon it started leaking within a year.
Donkeyface
May 8, 2021 11:01 PM
Shine49
Aug 29, 2019 04:54 PM
bionicdriver
Dec 6, 2015 11:31 PM
Chopchop
Jul 17, 2012 07:30 AM
ohnoesaz
Sep 17, 2008 08:08 AM
