Replacing Alternator
Old Jul 21, 2024 | 03:27 PM
theglot's Avatar
Default Replacing Alternator
I need to replace my alternator.
I am somewhat limited as I am recovering from a broken hip which limits my mobility.
First problem was the tension pully didn't want to move to loosen Vbelt.. Finally after much struggling I got it off, but will probably have to troubleshoot the tensioner.
Second problem; got the two bolts holding the alternator but doesn't seem to be room to remove it. Does it have to come out from the bottom?
Searched the threads for 430 minutes but could ot find this addressed.
Old Jul 21, 2024 | 04:50 PM
Default re: Replacing Alternator
You remove the bolts and 'rotate' the alternator counterclockwise (more or less) and work it out of the arms holding it.
You then kinda spin it over such that the pulley is facing downward and remove the plug and cable from behind and THEN work it around and get it out by moving it directly forward towards the radiator.
I don't know if you can do this from below, but I cant, as I have not lift. I"ve replaced my alternator four times in five years (DO NOT get an Alternator from NAPA, their rebuilds are awful).
Old Jul 21, 2024 | 06:44 PM
theglot's Avatar
Thanks, PizzaGuy.
I opted to jack up the car and take it out from below.
PIA but works.
Old Jul 24, 2024 | 12:24 PM
theglot's Avatar
Hints on replacing alternator.
Pizzaguy says it can be done from top by rotating it. I didn't have much luck, but took it out from the bottom.
Remove fan. It provides easier access.
Remove serpentine belt by putting 17mm socket on bolt on tensioner.
Once you remove old alternator, push out the bushings a little making it easier to install new alternator.
Thank you, Pizzaguy for many of these hints.
svo
Apr 16, 2019 01:02 AM
dsdesigns
35
Apr 21, 2016 09:55 AM
mb522xfire
Jun 19, 2014 07:20 PM
jayintheuk
Nov 17, 2009 07:56 PM
brittt1
May 16, 2005 12:13 PM
