Blower Fan
Old Jul 22, 2024 | 07:04 AM
mugsy99's Avatar
Default Blower Fan
Changed out my Blower Resistor last fall, now my Blower Fan is running even when the car isn’t running. I currently have fuse 36 pulled out in Hope my Battery doesn’t die. Any tricks or tips would be appreciated. I do have a new Resistor on order as heard they don’t last as long as the old ones.
Old Jul 22, 2024 | 10:56 AM
Default Re: Blower Fan
The way to determine what is wrong is not too hard, provided you are physically flexible!
If the fan motor is running with the key "OFF", then get into the cavity where the motor/resistor is and measure the voltage on the center pin of the three pin connector on the end of the wiring that goes to the resistor. DO THIS WITH THE CONNECTOR UNPLUGGED from the resistor.
If you have voltage on that center pin when it is unplugged from the 'resistor', the climate module is at fault.
The "map" of what voltage you should see at that pin looks like this:
Old Jul 23, 2024 | 06:08 AM
mugsy99's Avatar
Pizza guy, this might as well be in Russian as I have no clue about about electricity and such. Is there a picture of where to put the pointy ends of the prongs on test thingy?
DHS
Mar 31, 2021 07:01 PM
Nexxus
May 31, 2020 01:29 PM
rolandbrizio
Dec 9, 2014 10:27 AM
smokey847
Oct 11, 2012 02:36 PM
C-Fire
Feb 24, 2009 07:36 AM
