How to remove the pins from the throttle body connector?a
Old Jul 22, 2024 | 02:56 PM
JaNeily's Avatar
Default How to remove the pins from the throttle body connector?a
Due to my clumsiness, I broke the throttle body connector when removing it, so it won't stay tight to the throttle body when reinstalled. I have a new connector on order, but how do I remove the pins from the old connector? Thanks in advance!
Old Jul 22, 2024 | 04:35 PM
JaNeily's Avatar
Default Re: How to remove the pins from the throttle body connector?a
Got it. Since the connector was shot anyway, I just cut away the outside with a small side cutting pliers, and then I had access to the tabs that hold the pins in. Pressed them in with a small screwdriver, and the wires came right out.
Old Jul 23, 2024 | 12:08 AM
MAKE SURE you GENTLY bend those tabs back out so they re-click into the NEW connector case. Otherwise, one or more bay 'back out' of said new connector. Might save some headaches down the road.
Old Jul 25, 2024 | 02:26 PM
JaNeily's Avatar
Yup, gently, and not too far. A successful transfer has occurred. Now to get the rest of the engine back together. In another thread...
nickwe21
Nov 11, 2023 05:06 PM
Mistergee
Mar 16, 2022 10:19 AM
Tom3120
May 11, 2019 10:52 PM
gualtira
Sep 24, 2013 09:34 AM
huudoo
May 7, 2008 03:58 PM
