fuel rail and injectors
Old Jul 30, 2024 | 03:05 PM
Default fuel rail and injectors
After removing and reinstalling the fuel rail and injectors should the fuel rail be primed by opening the shrader valve and turning on the ignition before trying to start?
Old Jul 30, 2024 | 03:58 PM
xintersecty's Avatar
Default Re: fuel rail and injectors
in my own past when replacing injectors, I never bother priming the fuel rail. I just start the engine. The fuel pump will pressurize the rail. Any air in the fuel rail is blown out when the injectors are opened. If you had read the manual, it just says start the engine and check for leaks.
Old Jul 30, 2024 | 04:41 PM
Thank you very much.
Old Jul 31, 2024 | 10:17 AM
NeedsWings's Avatar
crank it!
Old Jul 31, 2024 | 11:46 AM
Triple what has been said, trying to 'prime' the fuel rail usually results with fuel spraying everywhere in the engine bay. One spark, WHOOSH! Turning the key to 'ON' position for a few seconds will take care of the fuel pressurizing, when you turn the key to 'start' and release it, the car will do the rest (since the starter will continue to crank until it has the fuel to the cylinders, and it runs).
Old Jul 31, 2024 | 01:38 PM
Spark that sum biatch up like Neil Armstrong heading to the Moon! LOL
AndyJ
May 2, 2015 11:10 PM
JEFASOLD
Aug 18, 2014 04:05 PM
crossmember
Aug 3, 2014 06:49 PM
boostmonkey
Apr 28, 2014 05:35 PM
murtazanooruddin
Dec 20, 2010 11:12 AM
