No crank. Cooling fan runs when key is on. Dash lights work. New Transmission Pisiti
Old Oct 25, 2024 | 07:38 AM
bobandsherry's Avatar
Default No crank. Cooling fan runs when key is on. Dash lights work. New Transmission Pisiti
no crank.
Old Oct 25, 2024 | 10:25 AM
Default Re: No crank. Cooling fan runs when key is on. Dash lights work. New Transmission Pi
Too much information.
Old Oct 26, 2024 | 02:14 AM
Originally Posted by bobandsherry
no crank.
It could be a bad relay control module, (RCM).
More information would be helpful.
Year? N/A or SRT6? Mileage? Does it make any noise when you try to start it? etc...
Old Oct 26, 2024 | 05:36 AM
initially, the car stalled after driving about five minutes and restored it after it about 20 minutes. It is a 2006 Chrysler crossfire limited coupe with around 80,000 miles. I bought the car. I replaced the transmission position position sensor. For about 30 minutes and then died. tried to hook up a code scanner, but it would not read the ECU when the key is inserted. There is no fuel pump sound, the rear wing will go up and the fan starts racing at a high speed. All the dash lights are on the battery and it is fully charged. There is no sound when you turn the key. It doesn’t click nothing disconnect the battery cables and hook them together and reinstalled. The car crank for about two seconds and ran and then died. I did that again same result ran two seconds and died.
Old Oct 27, 2024 | 01:04 AM
I would guess the RCM is bad. The RCM has a group of relays in it, one of them being the fuel pump.
You can get one off of amazon. You can replace it and see if it solves your problems. If it does, I would send your original out to @tighed1 and have it repaired. It is recommended to carry a spare RCM because they are known to fail.
Here's a link to the one on amazon:
Amazon RCM Amazon RCM
You should also carry a spare Crank Position Sensor (Use BOSCH only).
Old Oct 27, 2024 | 10:13 AM
Here's a link to the one on amazon: Amazon RCM
thank you so much for taking the time to help me out. I am going to pull the RCM and have it repaired. Also, do you have any suggestions for a code reader that will work on a crossfire. My budget is about $250 or less.
Old Oct 27, 2024 | 11:01 AM
CRP123 on Amazon
Old Oct 27, 2024 | 01:06 PM
BlueDRIVER - Buy the OBD2 sensor & download app on your cell phone. I keep the OBD2 sensor in the Crossfire's console & I typically always have my cell phone with me. I have somewhat more expensive scanners in my garage, but the BlueDRIVER is pretty close to these more expensive scanners.
Old Oct 27, 2024 | 01:15 PM
Attached Vehicle Spec file downloaded on my cell phone from BlueDriver app.
Old Oct 27, 2024 | 07:14 PM
tighed1's Avatar
Email tighed1@hotmail.com for the details on getting your RCM refurbished. You'll have it back in a week.
Old Oct 27, 2024 | 08:37 PM
I have the CRP 123, the same as ZERACER suggested.
dedwards0323 has the BlueDriver.
You should research these and see which one you like best.
Old Nov 6, 2024 | 07:59 PM
no crank.
thanks to everyone for their help I replaced the RCM or had it repaired by TJ that was recommended on this form. He did a great job and I had it back within a week. Installed it on the car and it cranked right up. Thanks everyone for your help and I’ll probably see you on here again.
Old Nov 7, 2024 | 02:43 AM
Thanks for the update. I'm glad that it's running again!
zxf
Aug 29, 2024 01:51 PM
Nefarious
24
Oct 7, 2023 04:34 PM
Romad
Apr 28, 2022 05:41 PM
rayludwiczak
Feb 2, 2020 06:54 PM
tabcontrols
Apr 26, 2010 12:25 PM
