Replacing Manual Trans backup light switch - how difficult?
Old Jan 13, 2025 | 11:16 AM
Gmarcelo's Avatar
Default Replacing Manual Trans backup light switch - how difficult?
Good day, everyone. My 06 Limited w/ 6 speed has both backup lights out. The bulbs are good and all other rear lights function properly. This seems to point at a failure at the backup light switch. Can anyone give me a sense of difficulty on replacing this switch? Looking at various under-car photos posted on this site, it looks like access to the switch might be blocked by a transmission mount bracket. Can anyone confirm this bracket is a problem, or if I can actually get to the bolt and switch without having to get the bracket out of the way? Removing the transmission mount would vastly complicate this job for me! Thanks in advance for anyone's experience with this fix!
Gerry
Old Jan 13, 2025 | 04:59 PM
Default Re: Replacing Manual Trans backup light switch - how difficult?
First, know that backup lamps are only powered when the key is ON.
Second, make sure Fuse 4 in the ICM is OK.
If the above is OK, the backup lamp switch (in cars with manuals) is a one-bolt job, there is nothing in the way.
Old Jan 13, 2025 | 09:38 PM
Here's a link for the part and if you click on the diagram below the part, it shows the location.
It should be a very easy job. Good luck!
LINK reverse light switch
Old Jan 14, 2025 | 08:30 AM
Gmarcelo's Avatar
Thanks, pizzaguy. I really appreciate your advice. I did check with ignition set to ON. I will take a close look at fuse 4 this evening. The service manual seems to indicate that fuse 4 also controls rear directionals and taillights, and all of those are working properly. But it is an easy check, I will take a look anyway. Your info on bolt access is much appreciated, that was the thing that had me worried. I have a switch coming in from FCPEuro, if the fuse 4 check doesn't solve the problem I will take photos of the switch replacement and add them here.
Gerry
Old Jan 14, 2025 | 08:34 AM
Gmarcelo's Avatar
Thanks much for this link, I appreciate it! I did find the part at FCPEuro, I hope to have it in my hand by the weekend and if I can I will post some photos of the process on this thread afterwords.
Gerry
Old Jan 14, 2025 | 10:13 PM
Gerry
That would be great to see!
Good Luck!
John
Old Jan 14, 2025 | 10:49 PM
Gerry
Simple 10 minute job to replace the back up light switch on our manual transmission
That's is what I needed to in September 2023
https://www.crossfireforum.org/forum...0-post100.html
ZERACER
Jan 27, 2023 07:15 PM
Dschnbgr
Jan 26, 2022 09:37 AM
notqytryt
Oct 27, 2021 11:45 PM
kaiser
Jul 22, 2012 12:44 PM
xfchris
U.K.
Jun 26, 2010 06:05 PM
