Breather
Old Oct 29, 2025 | 01:37 PM
theglot's Avatar
Default Breather
My breather has a small oil leak, which results in an oil smell in the cabin on occasion.
Read threads about this, purchased some black RTV and some stainless steel bolts.
Removed the 4 bolts and tried to remove the breather. It is stuck. No amount of prying wanted to loosen it.
Any suggestions?
Otherwise I can live with the smell.
I bought 50 screws. Anyone wanting a pair let me know.
Old Oct 29, 2025 | 11:53 PM
UrbanE's Avatar
Default Re: Breather
Is the item circled what you’re referring too?
Old Oct 29, 2025 | 11:54 PM
theglot's Avatar
Yes
Old Oct 30, 2025 | 01:34 AM
Originally Posted by theglot
Yes
There are 5 screws in the breather covers. From the driver's point of view; Left side has 3 screws, right side has 2 screws.
Here's my post on when I did mine: LINK - Breather covers and valve covers. There are a lot of detailed pictures with descriptions in the post. Hopefully it helps.
BTW, don't use a metal wire brush to remove the old RTV. The breather covers are magnesium alloy. Once you break the coating on them, any water will make them decay.
Gasoline works well to remove the old silicone.
Old Oct 30, 2025 | 07:21 AM
UrbanE's Avatar
Yes
I had one like that too. It appeared to be fused on. I even resorted to using a pry bar. After it finally came off i couldn’t be sure it wasn’t bent.
Simple solution, this is a common MB Engine. I went to a local pick and pull. Located a donor car and bought the valve covers for both sides
I paid $40 for both
The breather came off the donor covers in less than a minute. You might want to look into this option
fast, easy and cheap
Old Oct 30, 2025 | 09:39 AM
dcskmail's Avatar
Also re-torque the valve cover bolts to 7ftlbs to ensure they are tight. years of heat to cold temps can result in low torque
Old Oct 30, 2025 | 11:40 AM
theglot's Avatar
Thanks, everyone.
I will try again following the suggestions.
BeanMan
22
Aug 9, 2020 04:48 PM
nvrgvupjw
Aug 31, 2018 07:15 PM
Ned
Apr 20, 2016 07:04 PM
ciavarl
Jan 8, 2013 11:11 AM
Raz83
Aug 15, 2009 07:12 PM
