Oil loss
Old Oct 22, 2005 | 09:00 PM
anscv's Avatar
Default Oil loss
I currently have about 18,000 miles on my car. Before my last oil change (15,000), I had the oil light come on.. I had to put in two quarts of oil. I had to add another quart before I had the oil changed. I've looked for any leaks but I can't find any I just took the car in because the oil dip stick is showing 1/2 way down between the lines and I've only put another 3000 miles on it. They did a compression check 190 on all cylinders and said they couldn't find anything wrong. Has any one else had this problem?
Old Oct 23, 2005 | 02:03 AM
AlohaXFire's Avatar
Default Re: Oil loss
did they do a dry and wet compression test? If not, tell them to do it again. If the valve stems/guides/seats are leaking then they will only see it with a wet test.
Good luck!
~ Jess
Old Oct 23, 2005 | 06:59 AM
bobs's Avatar
If its burning that much oil after only 18,000 miles I'd say you've got some serious top-end problems. Did you pull the spark plugs and have a look? It should be pretty easy to determine which cylinder is causing the problem.
Does your dealer have a certified Crossfire tech? If not maybe its time to change dealers.
Old Oct 23, 2005 | 11:14 AM
anscv's Avatar
What would I look for on the spark plugs? I'm what you might call a back yard mechanic would some basic knowledge. It's been very frustrating working with the dealer, but in general I find this to be true of many dealers. That's why I try to do my own work when I can. I only take it to a dealer when it's under warranty or it's over my head.
Old Oct 23, 2005 | 12:39 PM
Dan Root's Avatar
Banned
Try a Mercedes mechanic, they have been working on these engines for years and might know!
Old Oct 23, 2005 | 02:25 PM
bobs's Avatar
Looking at the plugs can tell you a lot about the way the engine (or a particular cylinder) is running. Here are a few links that give some examples:
Link #1, Link #2, Link #3
TerryR
Dec 13, 2019 03:27 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
stlas69
Sep 14, 2015 06:45 PM
lazorouss
Sep 11, 2015 09:16 AM
