Intake how to LARGE IMAGES
Old Jan 9, 2006 | 10:25 PM
stryfox's Avatar
Default Intake how to LARGE IMAGES
Ok how to do intake.
You will need,
AVC-11096
This is the silicone elbow I used for intake you will need 2.
I ordered them from: www.summitracing.com $38.39 each.
You will also need some 3” exhaust tubing and mandrel bend a *45 on one end, trim to fit.
You will also need a total of 5 hose clamps at least 3.5”.
I will look for the k&n # I used but any 3” inlet short filter will do.
Ok that should give you a good idea where to start.
Let me know if you have questions…
*** Note!!! Unless you completely gut your air box and modify it there is no way it fit back over the motor.
Ta Da!
I still need to make a heat/splash shield.
Old Jan 9, 2006 | 10:38 PM
x'ed's Avatar
Default Re: Intake how to LARGE IMAGES
my friend who had an s4 had this custom headlight made that allowed air to flow through it. looks like that could be a good idea for this setup. any difference you can feel performance wise? can you post some sound clips?
Old Jan 9, 2006 | 11:09 PM
stryfox's Avatar
I think it sounds great. It feels faster but I wont know for sure till I get it to the track.
I don't have the gear to post sound clips. At least any that would be worth listening to.
Old Jan 9, 2006 | 11:16 PM
x'ed's Avatar
no video on the digi camera?
Old Jan 9, 2006 | 11:38 PM
stryfox's Avatar
Uggh I'll try when I have some time.
Old Jan 10, 2006 | 12:06 AM
x'ed's Avatar
its easy enough, just upload it to putfile.com, only takes 3-5 minutes...clips are greatly appreciated if you have time...
Old Jan 10, 2006 | 04:46 AM
HDDP's Avatar
Good Job...
Old Jan 10, 2006 | 09:40 PM
stallion8797's Avatar
Banned
I think if you made the top part y off and come into two separate intakes, it would be twice as good.
JK, great job, you may have yourself a little side business there...
Old Jan 10, 2006 | 11:13 PM
stryfox's Avatar
The how to is so people can do it themselves, I have no plans to make or sell this kit.
I think one pipes is plenty as the pipe is 3" and the maf is 3" It does not neck down anywhere.
Old Jan 20, 2006 | 12:22 AM
FirebaseD's Avatar
There is a simple modification that is good for about 1 hp. Just remove the soft black weather-strip at the rear edge of the hood. This allows high-pressure air from the base of the cowl to get under the hood at the rear of the engine, right where the intake is located. I know what you got, but think about what I just stated.
The downside is that this will increase the temperature of the air brought in through the fresh air vents.
Old Jan 20, 2006 | 12:44 AM
HDDP's Avatar
Look familiar? this is my buddy and his SC VW... The ducting travels straight to the throttle body. This is by far the fastest new BUG I've ever seen, he blows by me everytime we're out...
Old Jan 20, 2006 | 01:44 AM
x'ed's Avatar
somewhat similar, except it still had a functional headlight. only drawback was that it wasn't xenon like the other side....
Old Jan 29, 2006 | 01:45 PM
04WRBwrx's Avatar
Awe look how cute that intercooler is.. haha.
I often think the headlight thing is goofy, but its hilarious when stock hondas do it. Nice intake mod man, my dads thinking of doing that now.
Old Jan 29, 2006 | 05:09 PM
stryfox's Avatar
Anyone else try to make an intake yet?
I'd like to see how you make out.
I think it is worth doing...
Old Jan 29, 2006 | 06:35 PM
04WRBwrx's Avatar
stryfox, i showed it to my dad. He is definitely going to do it, he just wants to drive the stock car a wee bit longer. But i'll let you know how it works out.
Old Apr 5, 2007 | 08:16 PM
msheredy's Avatar
Twice as good looking maybe... Since there is only 1 throttle body only 1 intake tube is necessary. If you have 2 sources of air coming at one another it might cause some turbulence before the throttle body. The whole point is to make the intake more efficient... less is better here.
Hey stryfox, I was thinking about taking your idea one step further, check this out. Some might have seen this setup before on mustangs and it worked really well. It would take some modifications but it would shield the filter from the heat/water plus grab cold air from one of the best airflow places, the bottom of the car. It is from March Performance. Here is a link to the site. There are a couple more options too.
http://www.marchperf.com/pg29.html#93ramair
File Type: png
Old Apr 5, 2007 | 09:12 PM
stryfox's Avatar
Just be careful you don't go too low to the ground.
My coworker did that with his neon. He got stuck in a rain storm and hit a little puddle, you guessed it, blown motor...
Old Apr 25, 2007 | 04:05 PM
ViffeR's Avatar
Stryfox,
Can you fix the links to the pics? I'd like to check this out...
Old Apr 25, 2007 | 05:51 PM
stryfox's Avatar
Sorry they got lost on the server. I will see if I can find them on my computer and host them again.
Old Apr 30, 2007 | 11:11 AM
Cincinnati Slim's Avatar
Wink D.I.Y. is fun but the AMG set-up is great
Well if y'all just to have a "hardware store" looking CAI system go for it !
As for me I think the AMG/factory guys already have this thing figured out.
From my previous posts I've posted part numbers. Pictures are in my member's gallery. Plenty of cool air, factory/OEM fit and finish, dealer techs won't freak out when doing routine warranty work, race officials won't bump you up a class for aftermarket mods etc. Seriously, this set-up feeds a 350 horse AMG motor no problems, it's overkill for a N.A. 3.2 motor.
Here are the part numbers for this set-up...
Air intake tubes from radiator area to air boxes, Benz and Chrysler parts numbers as follows...
A 112 094 15 82
05135452AA
and
A 112 094 14 82
05135451AA
The rest are M-B/AMG numbers on the parts...
MAF "Y" pipe...A 112 090 01 29
Rt. Flex Tube...02 6367 A
Lf. Flex Tube...02 6367 B
Rt. Airbox...A 112 090 1001
Lf. Airbox...A 112 090 0901
Cheers,
Slim
Blackly
May 27, 2026 10:15 PM
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
Sep 28, 2015 07:40 PM
Dgiomatch1
Sep 20, 2015 01:05 AM
aerobluehal1
Canada
Sep 3, 2015 10:15 AM
