Navigation Installed in '04
Installing a Becker Infinity Navigation unit we found that the '04 Coupe was already prewired and we did not have to splice any wires at the amplifier. That made the job much faster.
The '04 was purchased new and never had a GPS unit in it. GPS does not appear as an option on the '04's in my papers.
An adapter for the radio aerial and a GPS antennae was all that was needed.
BlueCoupe's '05 had to have the additional wiring added, go figure.
It was even confirmed on my '04 crossfire that the wireing for that year is all there just like onehundered80 said. Just an adapter for the radio aerial and a GPS antenna was all that was needed. Finally some good info about adding the nav unit to our car
Guys did you forget? Antennae wire, antennae adapter (Becker sourced only) and GPS antennae.
Get these items and Bluecoupe will fit it for you while you talk to Beaner. It'll only take him 20 minutes and then you can chew the fat for another four hours.
Forgot about the wire, so all you need is the antennae wire, antennae adapter (Bluecoupe sourced
) and a GPS antennae.
2005 Ragtop
Oct 3, 2015 03:01 PM
