So confused 4ohm headunit with 4ohm amp into the stock 2 ohm amp with 4 ohms speakers
Old Aug 13, 2010 | 06:20 AM
huntsmcgee's Avatar
Default So confused 4ohm headunit with 4ohm amp into the stock 2 ohm amp with 4 ohms speakers
OK ya that sounds like no fun but here it goes. I'm really wanting to upgrade my sound system but the factory amp has me very unsure about the outcome. Now id like to get a alpine head unit and this new thing they have out now Alpine KTP-445 Head Unit Power Pack now what that does is boost the head units RMS from 18-45 all at ohms going to the OEM amp which i think i heard it was rated for 2 ohms as well as the speakers. So does any one have a clue what would happen with 45w RMS 4 ohms going into the 2ohm amp and pushing 4 ohm kicker ks650.
Old Aug 14, 2010 | 06:36 PM
PROUDGPAPA's Avatar
Cool Re: So confused 4ohm headunit with 4ohm amp into the stock 2 ohm amp with 4 ohms speakers
I Used To Work In Car Audio Install For Over 15 Years On Both The Retail And Dealership Side Of The Business.i Found A Solution To Your Problem Years Ago In The 1990's.you Can Add Any Din Sized After Market Head-unit To Any Factory Amplified System Using One Of Two Methods Listed Below:
1.connect Rca Cables To The Rca Output At The Back Of Your Alpine.cut The Cable In Half And Use The Covered Wire As Your Positive Input And The Braided Surround Wire As Your Negative Input Into An Factory Adapter Harness That You Should Be Able To Find At Any Car Audio Retailer. I Have Upgraded My 2005 Roadster Keeping The Factory Amp And Speakers With A Sony Head-unit With I-pod Connectivity,hd Radio, Satellite Radio, And Cd Changer Controls.i Also Added Two Amps Component Speakers In The Dash And Kickpanels.i Am Working On A Solution To Add A Speaker Pod Between The Seats For Rear Imaging. Let Me Know If You Have Any More Questions.
Proudgpapa
Old Aug 14, 2010 | 06:45 PM
PROUDGPAPA's Avatar
I'm Sorry I Forgot To Mention The Other Option Which Is The Best And Allows You More Flexibility. You Can Use Pac Speaker Level Converters Instead Of The Rca Outputs On The Alpine.the Converters Are Adjustable And You Can Set Them To Really Make You System Sound Great.
Proudgpapa
Old Aug 14, 2010 | 10:33 PM
huntsmcgee's Avatar
Default Re: So confused 4ohm headunit with 4ohm amp into the stock 2 ohm amp with 4 ohms speakers
So are you saying that when installing a aftermaker headunit the amp does notting? or does it still work
usprb1976
Apr 4, 2024 04:57 PM
pioneer4x4
Mar 18, 2021 02:17 PM
skeet370
29
Sep 18, 2015 05:53 AM
RacerXofFL
Sep 15, 2015 05:00 PM
caseydeankopp
Sep 13, 2015 07:25 PM
