Radio controls don't work
Old Aug 17, 2011 | 05:34 PM
cronus789's Avatar
Default Radio controls don't work
I installed a Pioneer 3300UB in my roadster last month. Installation went fine and all was well until today. Today none of the controls on the front of the radio will work - I can't change channels, volume, input or anything else. The remote doesn't work either. I checked the wiring and all seems OK. Anyone have any suggestions before I return the radio? I am getting tired of the same radio station.
Old Aug 17, 2011 | 07:44 PM
PNA's Avatar
PNA
Default Re: Radio controls don't work
I would think it has to be the radio................ return it.
Old Aug 18, 2011 | 07:02 AM
It could be that the "brain" of the radio has locked up, try unplugging ALL power from it for a minute or two.
I doubt this will restore it, and even if it does - you don't really want a radio that is prone to this.
However, many microprocessor based devices will "lock up" if the power feeding them is intermittent. Any chance you have a bad splice in a power or ground lead?
Other than that...
As PNA said, it's probably time to return it.
Old Aug 20, 2011 | 08:25 PM
cronus789's Avatar
Replaced the Pioneer with a JVC. I am very happy with the switch. The JVC looks better and is more user friendly.
Old Aug 22, 2011 | 08:40 AM
redeagle's Avatar
Does it have a removeable faceplate? If so -have you tried to remove and reinstasll the faceplate sometimes if the alignment is put off a bit (ie after a pothole) you lose contact and control. Simple but sometimes overlooked.
Old Aug 22, 2011 | 04:26 PM
cronus789's Avatar
I did try removing the faceplate with no success. I concluded that it was a bad unit and replaced it. No problems since. Thanks for the input.
amx1397
Jan 24, 2016 02:12 PM
tom2112
Dec 1, 2015 09:02 AM
bdh
Jul 9, 2015 09:40 AM
Blackout317
Jul 7, 2015 08:38 PM
pop49
Australia
Jul 6, 2015 10:10 AM
