Help with OEM AMP speed sensor
Old May 22, 2012 | 07:01 AM
crossfirefrank's Avatar
Default Help with OEM AMP speed sensor
I have a aftermarket head-unit and would like to disable the OEM AMP speed sensor. Could anyone advise me on how to do this. I'm guessing I can cut one of the wires leading into the amp but need help on which color and location on the connector.
Old May 22, 2012 | 09:05 AM
Default Re: Help with OEM AMP speed sensor
According to the schematic, it would the the dark green/white wire on pin 3 of the 'B' connector.
( the 'B' connector is the one with all the speaker wires, the 'A' connector comes from the head unit ) )
BUT DON'T BLAME ME IF THIS IS INCORRECT, THE SCHEMATICS ARE OFTEN INCORRECT
Hook a DC voltage meter to it and drive, see if it changes with speed ........
Old May 22, 2012 | 11:35 AM
SNAKEWOLF's Avatar
2004_Chrysler_Crossfire_Nav_install.pdf
This should help you
Old May 24, 2012 | 06:19 AM
Thanks for the info. only took 10 minutes to do.
PNA
Nov 12, 2020 04:44 PM
waldig
Sep 2, 2015 11:02 AM
pioneer4x4
Jul 27, 2015 02:04 PM
xfireon20z
Jul 20, 2015 04:35 PM
JEFASOLD
Jul 15, 2015 02:32 PM
