Radio has a mind of its own
Old Jun 20, 2012 | 05:58 AM
soccer1822mom's Avatar
Default Radio has a mind of its own
Hello! The radio in my Crossfire just randomly decides to not let me adjust the volume or change the station. Sometimes it just won't turn on at all. I've pulled and replaced the fuses, any suggestions?
Old Jun 20, 2012 | 07:28 AM
Default Re: Radio has a mind of its own
1. get aftermarket head unit.
2. get OEM radio from forum member that has upgraded to aftermarket head unit.
Old Jun 20, 2012 | 10:38 AM
dtinker's Avatar
Maybe the egdes of the bottons are dirty and sticking. Try a Q-tip and a little alcohol and clean especially where they go through the face plate. Then ,with your finger push the bottons, feeling for hang up. Hope this helps.
Old Jun 20, 2012 | 10:52 AM
If you'restill under warranty, it can be replaced by the dealer. Mine does the same thing.
Old Jun 20, 2012 | 11:49 AM
Just in case, if it is any "hang ups" with the microprocessor (doubtful), get the "keys" at Walmart and pull the unit out of the dash.
Now, unplug the connector and leave it out for at least 1/2 minute. This way, you KNOW that you have "unpowered it".
But I suspect it's dirty/worn button contacts and a bad volume control (also dirty/worn).
Personally, for various reasons, I like the OEM head unit. There are several members who have lightly-used ones for sale (as mentioned above). BMorgan had one at one time, others do too!
Old Jun 21, 2012 | 09:20 AM
What a deal I found for you !!!!
CHRYSLER CROSSFIRE OEM RADIO | eBay
Old Jun 21, 2012 | 10:24 AM
PNA's Avatar
PNA
Great Deal--- jump on it. I found one out of a wrecked XFire and it cost me $75 -- and I thought that was a deal. I also have one in great shape out of my 04 but it is the early model with LED and not LCD. That's why I got a newer LCD version -- it's easier to read in the day time. Nothing wrong with my original but the LCD is so much better. The one for sale appears to be an LCD and it must be because it's out of an 07.
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
Sterling57
Apr 11, 2016 06:11 PM
smokey847
Nov 12, 2015 11:54 PM
brandoni
Sep 30, 2015 07:48 PM
Selbyl
Sep 26, 2015 04:15 AM
