Speakers not working
Old Oct 16, 2012 | 08:41 PM
bluetb's Avatar
Default Speakers not working
I just bought my crossfire.The only speaker that worksi the passenger front.I have the oem nav radio.I would appreiate any ideas.
Old Oct 16, 2012 | 08:48 PM
Mrmiata's Avatar
Default Re: Speakers not working
Adjust the balance? Your rear sub may be working.. stock setup you hardly hear it.. did you feel behind the seat to see that it's dead? I say adjust balance halfway kidding.. but since the stereo is only 2 channels.. "if" no one has custom wired.. your left channel may be out?
Old Oct 17, 2012 | 01:57 PM
bluetb's Avatar
I adjusted the balance.Nothing happens.what are color of the wires coming out of the radio go to the speakers.Maybe I need the color of the right and left speakers wires coming out of the amp. both sides if you know them.
Old Oct 17, 2012 | 02:08 PM
Mrmiata's Avatar
This thread will get you started at least.. there are several threads on the stereo and amp wiring if you use the search engine.
https://www.crossfireforum.org/forum...amplifier.html
Old Oct 17, 2012 | 02:41 PM
Since you say this is a NAV radio, I assume that you bought an SRT6 or a Limited model.
Both of these have the Infinity amp under the front of the passenger side foot well.
The base model has no amp, and can be identified by black door handles, windshield surround and black ***** on the radio.
You may have a head unit issue, an amp issue or simply a wiring issue.
Mine did this once and I found that the connection to the door speaker that can be accessed by removing the little pop-out panel at the front of the door was corroded, cleaned it up and has been fine since.
PNA
Nov 12, 2020 04:44 PM
maxcichon
May 14, 2019 07:30 PM
Hoppy
Dec 7, 2018 07:36 AM
waldig
Jul 31, 2017 09:46 AM
pioneer4x4
Jul 27, 2015 02:04 PM
